Question about Dewalt d26451k 5" random orbit sander kit with hook & loop pad and dust collection
Cant figure out how to install the sanding disc's
How do i install the sanding disc's to the sander
    Sergeant:
    Habit-Forming:
  • 142 Answers
Step 01: Prep the Pad
Using the same technique of making my own sanding disks as shown in my Instructable "Renewing Sanding Disks", I modified one slightly by punching a 3/4" (19.05 mm) diameter arbor hole and cutting relief slits so the retainer nut would nest subsurface.
Step 2: The Build
1. Barrel style full body clamp with easy on/ off mounting
2. No physical or mechanical modification to the tool is needed
3. Slotted work surface table, adjustable in/ out, is centered with disk
4. Bench hook (lip) on front edge of base promotes immovability using just a single clamp
5. Simple "T" style adjustable miter gauge aids in precision work
6. Disks can be changed while tool is mounted by simply loosening and sliding off slotted work table
7. Easily accessible on/ off switch
8. Simple construction allows fabrication from cutoffs and drops
9. Model-makers especially, will find this tool most useful
Step 3: Parting Thoughts
For enhanced safety, a guard would be advisable, however I have yet to install one.
More details open the link
Best Disc Sanders For Sanding In 2018
Posted on Mar 05, 2018
    Genius:
  • 1,114 Answers
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Posted on Jul 23, 2009
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
Change a disc on the 5" sander on the belt and disc sander item 10027
please be more specific!!
guessing - bench top disc/belt sanders' discs usually use stick on backed sand paper discs ;)
Jan 13, 2015 | Sander Tools & Hardware - Others
Festool RO 125 leaves scuff marks when sanding
depends how important it is to vacuum the dust, most generic brand sandpaper discs will have different hole placements for the sander and the vacuum cant suck the dust up. if you are getting swirl marks from the edge of the sander, is the disc too small? a generic brand that is slightly larger may work but try and keep the sander flat or the excess disk can cause a little trouble with the finish.
Apr 27, 2014 | Festool 492271 5 Inch Stickfix Interface...
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
I have a Dewalt sander I am using for wet sanding on a boat hull. I have already burned one sander out do to moisture I figure is there a way to protect the new sander from this happening again I am...
Impossible not to get water in the bearings and motor. It is vibrating too fast. You need air sander. Or sand dry, then wet sand the primer by hand.
Dec 17, 2010 | Dewalt DW421 5'' orbital sander
NEED NEW VELCRO DISC PAD SANDING DISC WAN`T STICK
http://www.hitachi-powertools.co.uk/locator.html
This will take you to the UK dealer locator. If you are outside the UK you will find tabs at the top of the page to direct oyu to other regional sites.
Jun 13, 2010 | Hitachi SV13YB 5" Random Orbit Finishing...
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
How do i use this thing
Yes it should screw on and the sanding pads should either be sticky or velcro
Oct 02, 2008 | Ingersoll Rand Ingersollrand Dual Action...
Air sander Support
You can add different sanding discs to an orbital air sander to ensure that it is properly set up for a huge variety of different jobs. From heavy duty sanding paper for tough jobs through to buffing cloths in order to get a final polished finish at the end of the job. With most orbital air sanders, changing the disc takes just a few seconds, allowing you to get a variety of jobs done a lot quicker.
Aug 27, 2008 | Chicago Pneumatic C-P AIR SANDERS & FINISH...
Dewalt d26451k 5" random orbit sander kit with hook & loop pad and dust collection Logo
523 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
