It could be a clogged filter, a belt that broke, or a bad pump or motor. There could be a bad relay, switch or controller that sends a signal to the motor. The model number might narrow the cause, but unless you are a do-it-yourselfer, you may want to call a repairman.
Does the pump make noise, are there any error messages?
consult your owner manual about you are unsure about if the machine is acting anormally Some machines, is running hot water during cycles, other cold water during cycles.
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
you have to unscrew the front grill and under the coil there is a drain pan,look to the side between the electricals and the coil and you'll see the drainout for the condensate.u have to blow out from there:-)
After wash the water drains out of machine automatically but its not drainout means the drain motor is not working properly or proper power supply is not given to the drain motor
there is adjustment for that inside of watch or it just may need a little cleaning inside recommend take to jeweler and have serviced if you want to try cleaning at home simply take off back cover and clean with a little cigarette lighter fluid put little bit in wash around and drainout (do not soak) allow excess to evaporate out and replace battery and cover hope this helps
