My sony sdm-p234 monitor wont turn on everytime i turn the power on after a couple of second turns off?
    Sergeant:
  • 338 Answers
Can u enter the monitor menu for adjusting brightness and such?
if yes, connect it to another computer,
if working now - fine!
then your computers graphic card could be the problem!
if not : it is posisbly broke
Posted on Jul 23, 2009
  • tsounoi Jul 21, 2011
    I exactly have the same issue with my Sony SDM-P234. This has nothing to do with the computer or graphic card since I'm having this issue with different computers and different graphic cards (a mac mini and a vaio laptop). No solution yet, but if got any I'll post it here.
Power
Either a loose/bad power cable or the backlight is failing.
Jan 30, 2018 | Sony SDM-HS95 19" LCD Monitor
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Sony sdm-hs73p LCD blacks out
Common problem in the HS73/93 is bad soldering works in the lamp assemblies, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
But look for bad caps (leaking/bulging top) first in the power supply section.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Sony SDM-HS53 Monitor Goes Blank
I used to have the same problem until I discovered that the cables in the back of the monitor weren't securely connected. I have a very similar model monitor to the one being displayed here
Apr 03, 2007 | Sony SDM-HS53 (Black) (Gray) 15" LCD...
SDM-P234/B Won't turn on
Follow this procedure to troubleshoot the monitor. NOTE: Since each of these steps represents a possible solution to this issue, check the display function after completing each step. 1. Download and install the latest video drivers for the video card. 2. Disconnect the computer and monitor from any surge protector or power strip and plug it directly into a known working wall outlet. NOTE: If the display returns after completing this step, the problem is isolated to the surge protector or power strip. 3. Ensure the monitor cables are connected correctly. 4. Perform a monitor self-test. 5. Adjust the monitor brightness and contrast levels. NOTE: Refer to the monitor manual or user guide for specific instructions on how to adjust the monitor brightness and contrast levels. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. 6. If possible, connect and use the monitor with a different computer. NOTE: If the monitor functions properly, then the problem is isolated to the computer to which the monitor was originally connected. 7. Ensure that the keyboard and mouse are connected correctly. 8. Troubleshoot the computer display configurations in Safe Mode. 9. Remove any hardware that has been added to the computer. This includes any added memory, internal or external drives, and any type of adapter card (network, sound, video, USB, etc.) . Let me know what happens. Good Luck, Tim
Feb 16, 2007 | Sony SDM-P234/B 23" LCD Monitor
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
