Question about Panasonic TH-50PH9UK 50 in. Plasma Television
I have a 55 inch Panasonic monitor th-50ph9uk and I can't seem to get an sound out of any one of the outputs what should I look for or how do I fix it
SOURCE:
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: screen keeps turning green
My Panasonic Plasma television started doing a green screen also. When it does it to me, is when I use the Last button or the Fav button. This is with Charter Communication. If I go back and forth, to various stations, then one station will turn green. So by trial and error, I found that when I clicked on a station, the screen would turn green. I had to push the Guide button, then the guide would come up, then push the Exit button, to get rid of the Guide, and then it would be on the station you wanted. If that does not work, then I have to just turn the TV off and turn it back on. It is rather annoying, however, as long as I can get rid of it, I can deal with it, instead of always turning the TV off. I don't know if this happens with all TV's or just Plasmas. If it does, I will not get another Plasma, if it happens with all TV's, maybe it is the remote, or the cable company. I just don't know.
Posted on Feb 18, 2011
eagle338
  • 4889 Answers
SOURCE: i have this plasma monitor
Sounds like a problem with the main A/V board can you please take a picture of the screen and post it here so that I can have a look?
Posted on May 31, 2011
SD Tech
  • 14553 Answers
SOURCE: panasonic plasma is getting loud buzzing sound and no picture,th-50ph9uk
power supply is most likely
Posted on May 15, 2012
tim599010
  • 216 Answers
SOURCE: Problem with plasma display on Panasonic TH-50PH9UK television
there is an x-buffer and a y-buffer. by disconnecting these and noticing if the picture changes you will be able to identify if it is on of these boards or if it is the screen itself. Youtube also has a lot of helpful videos. hope this helps
Posted on Jan 21, 2015
Jan 21, 2015 | Panasonic TH-50PH9UK 50 in. Plasma...
My screen is cut off at both ends picture is stretched out
You could be in overscan mode. There might be a video button on the remote that allows switching between the various video output mode.
Oct 28, 2014 | Samsung Un55d6000 55 Inch 1080p Led Hdtv
My Panasonic TC-p50s1 sound stops working. If I change th channel the sound comes back then it stops again how can I fix it
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 01, 2014 | Panasonic VIERA TC-P50ST50 50-Inch 1080p...
MY TV THYE LIGHT FLAS 10 TIMES AFTER ON
if you want to fix it ur self, open it and tell me when ur ready ..
www.tvrepair.localdomain.me
Jan 13, 2014 | Panasonic TH-50PH9UK 50 in. Plasma...
2 blinks panasonic 55 inch
First reseat connector p25 on the power board. If this does not fix it let me know.
Aug 31, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic TH-50PH9. The green ligth is on but I have nothing on the screen. When I push any botton on the remote, the green light blinks. No menu. nothing. Any ideas would be appreciated
Hi, First of all check your cable connections on the back make sure they are properly connected and in the right place.
Secondly make sure the settings in the menu are set to TV, DVD etc... what you want to watch.
Thirdly read you MANUAL for more info.
Jun 04, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My 50" panasonic tv screen goes completely green I turn off tv and restart and the picture is still great, but it is doing this more frequently
my 50' panasonic some channels are in another lanuage then some channels have no volume the people mouth are moving but no words then some channels are good.
Oct 03, 2010 | Panasonic TH-50PH9UK 50 in. Plasma...
Panasonic TH-50PH9UK 50 in. Plasma Television Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
