Question about Samsung VP-D101 Mini DV Digital Camcorder
Wont switch on
I have not used the camera for over a year but after charging the batteries it wont switch on.....nothing at all,any ideas.
    Problem Solver:
  • 3 Answers
Re: wont switch on - Samsung VP-D101 Mini DV Digital Camcorder Video Cameras
Its dirty :)
Posted on Mar 01, 2008
0 characters
3 Points
clean the mode selector switch with contact cleaner spray, which lays beneath the cassette drive mechanism.
Apr 07, 2016 | Video Cameras
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
Jul 21, 2011 | Sony DCR-HC52E Mini DV Camcorder
Camcorder will not turn on without being plugged
If the camera is turning on and is able to be used normally while plugged in to an AC wall pack, but not using the battery, there is probably a problem with either the battery or the internal power switch to go from AC to battery.
Check the battery with a voltmeter to insure you have a fully charged battery. It would also be a good idea to use the voltmeter on the camcorders power tabs to make sure the camcorder is passing the correct voltage to the battery. The amount of volts should match the volts on the battery.
If it's a battery issue, batteries plus has a replacement for this camcorder. If not, it's a switch within the camera (software most likely) and there's not much you can do other that try to reload the camcorders firmware if it is available fromt eh Insignia-Products web site.
Hope this helps!
Feb 08, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
My dcr sr82 just stop working while filming. the battery appeared to have 60 minutes. now the camera wont charge or turn on with the power cord nothing
Thank you for using FixYa for your problem
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Sony Handycam DCR-SR62 Camcorder
Power problem
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Jan 03, 2008 | JVC GZ-MG130U Camcorder
Won't start
how old is the battery? if it's more than 2 or 3 years old, it may not hold a charge. swap a known good battery and see if it works.
Dec 10, 2007 | Panasonic AG-DVC30 Mini DV Digital...
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
Won't turn off
the On/Off/VTR Switch doesn't function anymore and the camera is a month old. Basically anytime the battery is in the camera or the camera is plugged in, it remains 'On'.
That means you can't charge batteries or use VTR mode, or turn the thing off. Way to go on this one Sony.
Oct 12, 2006 | Sony Handycam CCD-TRV87 Camcorder
Samsung VP-D101 Mini DV Digital Camcorder Logo
77 people viewed this question
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
