Question about Envision H190L Monitor
What cable connects to the white ten pin connector on the aim?
  • Siddique M A May 11, 2010
    Please clarify what is "Aim" . This will help me understand the issue better. The monitor you are referring to has only 1 power connector and 1 15 pin VGA connector that will connect to your computer's video card / onboard VGA connector. Please refer to the manual for more information.http://www.aocdisplay.com/envision/manua...
    President:
  • 3,085 Answers
DVI Digital Video Interface...you don't need it.
The 15 pin works better.
Posted on Jul 23, 2009
Hello......can anybody give any solution for this problem : my VGA Cable disconnect from the 15 Pin gents connector of Crt monitor of philips model no. 107E61 I want to fix it but I could not understand...
These connectors come with 15 pins and 9 pins. But be carefull, the nine pin connecter uses a tottaly different color code. Thats for an oldschool gamepoort or midi connector. But I think the vga connector has 3 rows of pins total of 15. But the nine pin connector has probably two rowes of pins. And thats no vga connector, but an connector for an serial port.
If it has three rowes (see Fig-2 below) but uses 9 pins then its an RGB instead of VGA.
Fig-1
Fig-2
Fig-3
Mar 19, 2017 | Cars & Trucks
Replace motherboard
Rob, Rob, Rob.............if I told you a thousand times, I............
Oh.......... where was I?
1) Power cables from Power Supply to motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237538&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3878557
A) 24-pin ATX main power cable;
Looking at the motherboard view the Right side. To the right of the Blue 39-pin IDE connector, is the 24-pin ATX main power cable connector, on the motherboard.
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The power cable connector has a Lock on one side, and the motherboard connector has a matching Lock Tab.
When the power cable is deemed to be installed Correctly, and Properly; the Lock's hooked end is over the Lock Tab.
[Note* Color of connectors does NOT matter ]
B) 4-pin ATX +12 Volt power cable;
The processor socket is white in color. Around it is the black mounting ring.
The 4-pin ATX +12 Volt power cable connector on the motherboard, is to the Left/Bottom corner, of that black mounting ring.
Square, whitish (Opaque), and 4 socket holes.
This is a general example of a 4-pin ATX +12 Volt power cable; and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) Peripheral power cables from Power Supply;
A) The Harddrive is a SATA unit. Uses a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
B) The optical drive/s (CD/DVD drive) are also SATA units. They use a SATA power cable.
A SATA power cable's connector has 15 contact pins. Between it, and the SATA data cable, it has the longer connector.
Peripheral Data Cables;
This is a general example of a SATA data cable, it's connector, and a SATA connector on the motherboard,
(Note* Color does NOT matter),
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Here you can see the L-shaped opening of the connector, and matching L-shaped tab on the motherboard connector.
Most SATA power cable connectors, and SATA data cable connectors, have a lock. All you see is a 'bulb' type affair on top of the connector, that you squeeze down with a thumb tip.
Depress to remove, depress to install.
A 90 degree elbow connector for the SATA data cable, is used on the Harddrive, and optical drive. The straight connector end of the cable, plugs into the motherboard.
There are two SATA connectors on the motherboard. One White, one Black. One of them should have a SATA1 next to it.
(Or one will at least have SATA2 next to it)
SATA 1 connector is for the Harddrive. SATA 2 connector is for the optical drive.
The beauty of SATA is though, you can connect any SATA device, to any SATA connector on the motherboard; and BIOS will find it.
So it really doesn't matter what you plugged in where, as far as those two SATA headers are concerned.
3) Processor Fan cable, System Fan cable (Computer case fan);
Going back to the HP Support page above, and Motherboard Specifications; scroll down the list.
Click on the + sign to the left of the blue - Motherboard layout
Below the ATX12V1 connector is the System Fan connector.
(SYS_FAN)
This is where the computer case fan connects.
(ATX12V1 connector, is the 4-pin ATX +12 Volt power cable, connector)
Above the Ram Memory slots, and a little to the right; is the Processor Fan connector. Power to the fan. (CPU_FAN)
4) Front Panel audio connector, optical drive audio connector, Front Panel USB connectors;
Bottom edge of motherboard, from Left to Right;
Yellow connector is AUDIO1. Front Panel audio.
White connector is ATX_IN
For the audio cable from the optical drive.
Black connector (HD_AUDIO) is also for the Front Panel audio.
Don't know how they have the Front Panel audio, hooked up.
YOU will. The cable connectors to them are different from each other.
Further to the right are two white connectors. EACH one can support TWO USB ports.
One should be for the two USB ports in the Front Panel.
The other will go to a Card Reader in the Front Panel.
All the way to the right corner is the Front Panel header.
This is where the main wires from the Front Panel go.
Power On switch, Power On LED (light), and Harddrive activity LED (light)
The cable, and connector should match that 9-pin header.
If not here is an HP 9-pin Front Panel header - pinout,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the photo, and pinout. (Dave G)
Believe that is it.
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Regards,
joecoolvette
(Ya know I was jus kiddin' above, right?..............
Rob?...................................................................Rob?)
Nov 27, 2012 | Compaq Presario SR5712F (SR5712F-B) 19 in....
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
How do you connect a cable connector back on to the tv
If it is a cable, with just one pin, connect it to the Single isolated pin behind the TV, where it will fit in correctly. If you have three RC jacks, yellow-red-white, connect these respectively on IN marked positions on the TV. But connect the yellow pin to yellow RC socket only. Never connect it to other sockets, because this video. You can connect the Red and white to left and right channel of audio.
Jul 26, 2012 | Sharp Televison & Video
Recently changed the power supply. There is no video output. Where can I download the motherboard schematic?
Right here at HP Support,
1) Motherboard Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00361570&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459491
Scroll the page down to the top view illustration, and photo.
A) The motherboard uses a 24-pin ATX main power cable.
In the illustration the connector on the motherboard is on the right side.
It is an empty rectangular box with ATX Power Connector in it.
On the motherboard photo it is the rectangular white connector with two rows of 10 socket holes, and is to the bottom right of ram memory slot 2.
Another example of a 24-pin ATX main power cable,
Ensure that the 24-pin ATX main power cable's connector, is locked into place on the motherboard's connector. The lock tab on the main power cable must be hooked over the tab on the motherboard connector. This ensures that the main power cable is in all the way.
B) The motherboard uses a 4-pin ATX +12 Volt power cable.
The connector on the motherboard is a white square connector, with 4 socket holes.
In the illustration it is to the bottom left corner of the Processor socket (LGA 775), and has ATX12V underneath it. This power cable's connector also has a lock tab.
Another example of a 4-pin ATX +12 Volt power cable,
Power TO the motherboard, that's it.
Power FROM the motherboard:
C) System Fan, and CPU (Processor) Fan.
Abbreviated as SYS_FAN, and CPU_FAN to the bottom left of the ATX12V connector.
(4-pin ATX +12 Volt connector on the motherboard)
The System Fan is the computer case fan.
CPU Fan is the Processor fan.
D) The four SATA headers on the bottom right in the photo, (Blue, Orange, Black, and White), are for the SATA data cables.
They connect to a SATA harddrive, or SATA optical drive. (CD/DVD drive)
(They are an L shaped connector inside, with 7 pins inside)
Power for these SATA devices comes from the Power Supply.
The Power Supply has SATA power cables.
Example of an average SATA power cable,
(L shaped connector with 15 pins inside. The longer connector between a SATA data cable, and a SATA power cable )
Did you forget which SATA data cable plugs into where, on the motherboard?
Don't sweat it.
The beauty of SATA is that you can plug the harddrive's SATA data cable into ANY of the SATA headers (Connectors) on the motherboard, and BIOS will find it.
Same with a SATA optical drive, or any SATA device, for that matter.
IF, your SATA harddrive has a place on the back for BOTH, a SATA power cable, and a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
Using both will eventually burn out the SATA harddrive!
Example of a 4-pin standard Peripheral power cable, (Misnomered as 'Molex'),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
From there the main optical drive, (CD/DVD drive), has to have the audio cable plugged into the audio connector on the motherboard.
(Plus the power cable, and data cable, of course)
In the illustration this is the header down in the very far left corner, and located towards the bottom edge.
It has CD_IN marked underneath it.
In the photo it is the Black rectangular connector in the very far left corner.
If you didn't connect the 4-pin +12 Volt power cable, your Processor isn't getting any power.
No Processor operating, No computer.
No Signal on monitor.
(No video signal)
Regards,
joecoolvette
Jul 24, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
Hannspree tv
This is a very difficult question to answer without knowing more info, but here goes:
Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
May 12, 2008 | Hannspree HW191D LCD Monitor
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Envision H190L Monitor Logo
75 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
