Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My Whirlpool ultimate care II dryer stopped heating up. Everything works fine, vent is clear, just no heat. Heating element? Fuse somewhere in dryer? Other? Thanks, Joe
    President:
  • 1,865 Answers
You have to use a multimeter and troubleshoot the problem by testing the components in the heating circuit
Posted on Jul 23, 2009
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer doesn't heat up
2. Heating element
3. Thermal fuse
Jul 09, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Air not heating up in whirlpool dryer
Jun 25, 2009 | Whirlpool LER8648P Electric Dryer
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool ultimate ii electric dryer stopped heating
change out the heat element, you can get the part at Sear
Nov 27, 2008 | LG DLG2524 Gas Dryer
Ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
May 24, 2008 | Dryers
Whirlpool super cap. electric dryer imperial
element or thermal fuse at top of element housing most likely if either is bad ck vent system before using very long plugged vent can cause overheat long dry times and premature failure of element
Apr 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
907 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
