Question about Audiovox VOD102 Car DVD Player
The disc play will not accept or eject DVDs - Audiovox VOD102 Car DVD Player
  • soolai Jul 23, 2009
    we can not get a DVD in the player. It will not accept any DVDs.
    Our Audiovox DVD player in our 2004 Toyota Sienna will no longer accept DVDs. Nothing new has changed. It worked on Monday and then not on Tuesday.
  • 3,037 Answers
Bad tray motor is usually the problem when this happens. Have someone with electronic expertise open up the player. Then have them apply voltage to the motor to see if it will work, if it doesn't, then have them replace it. Let me know how this turns out.
Benjamin
Posted on Jul 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Please try to clean the DVD Player with a Lens cleaning DVD as the lens might need cleaning.
Please revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jul 23, 2009
    Hi
    If it will not accept the DVD then you need to follow these steps:
    Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
    Step2Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
    Step3Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
    Step4Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
    Step5Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
    Step6Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
    Thanks
    Rylee
The DVD-VCR unit won't accept any DVD - blank or with content. It says "LOAD" but then ejects the DVD. Same DVD works in an identical Samsung unit in another room.
You may have a dirty lens on the DVD read head. There are CD/DVD cleaning kits available at some drug stores and electronic stores. Do not get a "CD cleaning kit" (that only cleans the discs), get a "CD/DVD lens cleaning kit" (it will have a special CD and cleaning solution) for $10 to $20.
If that's not it the DVD illumination LED may be dead. If it still plays CDs, but won't play DVDs, that's the problem. There are separate LEDs for playing CDs and DVDs.
Either way, if the cleaning doesn't work, it has to be fixed in an electronics shop.
Oct 06, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Make movie disc ejects before
It sounds to me like the DVD ROM in your computer has the problem playing it's DVDs, so what happens when you play it in another Computer with it's DVD ROM?
Aug 10, 2008 | Pinnacle Televison & Video
The tv works but the dvds wont play. The symbol showing the disk is trying to read appears and stays on screen but nothing ever happens. When I try to eject the disc it won't. I have to turn it off and on...
my dvd player doesn't play all types of discs, especially homemade like ones ripped from a home computer. However, i do not play many dvds, yet i have replaced the players many times. I dont think that most dvd players are built to last. Sounds like you have 1 built-in (to tv). The players are cheap now-- your better off saving the headache and replacing it- The last one i bought was $30.00 on sale-get a cheap 1 cause i think they all have a short lifespan.
Aug 31, 2009 | Disney DTD1363-CAR 13" TV/DVD
DVD player won't read DVDs - goes straight to blank blue screen
tried the cleaner disc you can buy one at
best buy or waltmart
Aug 25, 2009 | Initial DTV-172 17 in. TV/DVD Combo
Player won't read the DVDs
some players won't play burnt discs. If you are using a factory made disc and you still get this, then you can try and clean laser lens with rubbing alcohol and cotton swab.
If the cleaning doesn't work, then the laser lens circuit will need to be replaced.
Aug 05, 2009 | Televison & Video
Samsung DVD recorder
did you try a lens cleaner disc?
Jul 30, 2008 | Televison & Video
LCD TV/DVD PLAYER COMBO - DVD WON'T ACCEPT A DISC
Turns out my suspicions wre correct about the DVD player being "sluggish" from lack of use. By continuing to exercise the drive motor by hitting play and eject while simutaneously attempting to insert a disc finally paid off. Now it readily accepts the disc and everything is functioning as designed. Trust me, I'm not going to let it sit idle for anymore extended periods...................baltogas
May 28, 2008 | Akai LCT3201TD 32 in. LCD Television
Dvd rom problems with my macbook
Does the computer immediately return the discs after they're inserted or do you have to manually eject them? If it's trying to read the discs then there could be a problem with the type of disc. However if it just ejects the disc immediately, there could be a recognition problem. So, if your computer doesn't recognize that a disc is in the drive, you can check several things. 1. Check to see that the computer actually reads DVDs. To do this, open the System Profiler in the Utilities folder. Click on ATA/Devices and Volumes/Disc Burning. Those are three different options but each will tell you if the drive actually does run DVDs. If it shows DVDRW or DVD, but if it only shows CD or CD-RW, then it won't play a DVD. 2. If it shows that it accepts DVDs through the System Profiler, then you'll need to check to see if the actual drive is attached. You can open your computer through the battery with a screw driver. Once open, you'll need to check the connecting cable to the drive. If it's attached properly/securely, you may need to take it to a technician. The drive me be malfunctioning and need professional repair.
Feb 19, 2008 | Apple MacBook Pro Laptop Computer with...
DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Sep 18, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
Audiovox VOD102 Car DVD Player Logo
144 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
