Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Model frs6hr4nw1 side by side frigidaire cool but not cold in freezer and frig(compressor runs but not very long). Found a black control box in the frig behind a panel when i tapped on it the light in the frig flickered is this a high failure part? Thanks for any help!
  • 153 Answers
Well u should read the menual and then do anything but i sugeest plase get physical assistant or an help of the expert to solve it. ur proccesor seems to work but need an expert look.
Posted on Jul 25, 2009
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Freezer defrosting all frozen foods and frig not cold, still running
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire model # FRS6LF7J type 7 runs but it don't get cold in both side. after reviweing it, i found that the fan inside the frizer is not working, its new frigidaire and had it home for 9 weeks.
Well, that fan must run to cool properly but that might not be the only problem, The fan is probably controlled by the control board in yours since it's a new one. The fan behind it and in the freezer should run when the compressor is running.
Sep 08, 2010 | Frigidaire Refrigerators
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Jan 28, 2009 | Frigidaire FRS26R4A Side by Side...
Frig and Freezer not working.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Mar 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore refrigerator model #106.53502300
Clean the coils.
If you have then there is a small fan that blows air across these coils, it is on when your freezer turns on. This would allow you to see if fan works. (usually when the fan fails you loose your freezer, bad repair people won't tell you to check fan)
Seals are a big issue. A good test put dollar bill into the door and try to pull out with door closed. It should be hard to remove. Seals are cheaper than new frig. A small air leak will lower cooling
Dec 01, 2007 | Frigidaire PLRS267ZAB Side by Side...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
