I have a Kenmore Top-loading washer model # 110. 13202200. Everything works except "spin". The motor works to agitate but when the dial gets to a spin is supposed to start everything just stops. There's still power to the machine and the drum is not seized, I can turn it easily by hand, it just stops cold.
  • jnpadula Jul 23, 2009
    are you sure it's that complicated and not just a relay or swithc? because the motor works fine in agitate, it just dosen't spin.
  • jnpadula Jul 24, 2009
    never mind, i fixed it. It was just a broken wire to the switch
    Brigadier General:
  • 8,619 Answers
Hi
If washer is running, remove power and remove cabinet. Use a piece of insulated wire to by-pass the lid switch wires, turn the timer to spin and pull out the knob, push the knob back in and pull it out again. Watch for the clutch drum to turn (brown section in picture A). If it is turning but the inner wash tub is not, then more often than not you have a worn clutch lining or a weak spin spring, also the brake may have seized up. If the clutch drum is not turning and washer is not spinning, often the failure is in the transmission gear box. (See picture B).
You may have to get the gear-case out. Then take a look at that tan colored part in the middle of this picture.
If the 2 drive "fingers" are broken off, the clutch can't dis-engage the brake and this means no spin.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 23, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jul 23, 2009
    The issue is not with the relay as it agitates and the motor is running. You need to follow the above mentioned procedure and check what is wrong.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Jul 24, 2009
    That's very nice that you have been able to fix the problem.
    Thanks
    Rylee
  • Rylee Smith
    Its good that it was just a broken wire.
    Thanks
    Rylee
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Washer won't agitate. New transmission...new timer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load, direct drive Whirlpool / Kenmore washers use a reversing motor.
It turns one way for agitating and reverses for draining and spinning.
It sounds as if either the motor is shot or one of the connectors is bad.
As a place to start, see the Whirlpool Service manuasl (with wiring diagrams) for their top load, direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Feb 13, 2010 | Kenmore 24832 Top Load Washer
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
