SOURCE: My Cecilware GF-10 LP deep fryer the pilot will not light.
on that cecilware fryer there is a regulator to the right of the pilot light unsrew the aluminum cap and take off cap then you will see a white plastic screw turn that screw clockwise until it stops this will give the fryer more gas this could be your problem the regulator is silver and inline with the gas pipe comming from the back
SOURCE: Dean #SR142GN fryer want to convert to LP Can we
give me a shout at [email protected]
I have the part #'s you need & prices and would be able to get that out to you asap.
captrick
SOURCE: ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
SOURCE: imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
SOURCE: Need to know how to reset the LP Gas flow for a
If you just installed a new, full tank of propane and turned it on and the burners wouldn't light.
Turn the tank off, disconnect from the grill hose (you'l hear a whooshing sound and smell gas, but that's alright). Wait several minutes and reconnect the hose to the tank. Turn the gas valve on very very slowly, until it's full open. Now, try lighting your grill.
Remember, you will need to turn the tank valve on very very slowly every time you change tanks or turn the tank off after grilling.
What happened was this ... When you turned the tank on quickly it locked up the grill's gas regulator. Doing what suggested usually solves the problem. Oh, one other thing ... be sure your tank is not empty. The grill you have uses a lot of gas.
Testimonial: "thanks"
