Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Cannot push forward
My Bissell Powersteamer Clearview will not push forward without the front wheels locking up. only works when I pull it backwards.
please advise.
Thanks,
Del...
    Scholar:
  • 164 Answers
Sounds like tear down to me to find out whats jamed in the whells ore the belt there not much to fix there things
Posted on Jul 25, 2009
I purchased my Bissel PowerSteamer Clearview a few years or so ago, and cannot find where I filed the manuals. If I find the actual seriel number on the Bissel PowerSteamer Clearview, Is there a way that I...
No need my friend. Go here. All documentation is here...and....it's free! Hope this helps : )
http://www.bissell.com/user-guides/?searchtext=1699%2520pro%2520heat&searchType=search&mode=228
Jan 07, 2011 | Bissell 1699 ProHeat Clear View Upright...
Changing belt on bissell powersteamer clearview 1692
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 11, 2010 | Bissell 1692 PowerSteamer Upright Vacuum
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a Bissell PowerSteamer ClearView How do I
I removed the pump belt and the brush drive belt for replacement. I can see that the brush belt has little ridges to line up on the brush gear. Its the pump belt that I need help with. The flat belt goes over the shaft sticking out of the pump, but the other end appears to have a channel that the belt fits into and around. Only when I put it togeather that way the belt is off center, does the belt fit up over the rounded (pink) end before the channel or is it supposed to fit in the channel
Jan 05, 2010 | Bissell 8806 Powersteamer Upright Vacuum
My Bissell Proheat 12 amp is hard to push forward(whether on or off). There is a loud clicking noise when pushing forward and it ''jumps'' up on every loud click. It's OK when pulling backwards, sprays and...
I had this same problem and here is what solved it for me. On a previous cleaning session, my wife decided to take the two front screws out of the clear plastic shroud that covers the brushes in order to clean behind it. Upon re-installation, she did not secure the top part correctly. On the end near the water tank, there are two tiny half-moon tabs that absolutely need to be seated in their opposing slots in the chassis.This allows for a good seal which enables the machine to **** up the water. It also keeps the front cover level and from dragging on the carpet when pushing it forward. Both were problems I was experiencing. Hope this helps!
Mar 09, 2009 | Bissell 1699 ProHeat Clear View Upright...
Foot pedal broken
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=629933
Foot pedal broken
Posted by Monte79 on May 28, 2008
I have Bissell Power Steamer Clear view IIII #3105403. I let someone borrow it (mistake #1) and he over extended the foot pedal that angles the upright during use. The pedal is still connected, but the power steamer is locked in the upright position. There is also a bit of dirty water in the bucket, and i cannot empty it because it's basically locked in now. HELP
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem with your Bissell, it sounds like he bent the handle release lever and you either need to bend it back or replace it depending on the level of damage to the item. Please feel free to contact the Bissell factory to see the best way to fix the problem, it is not an expensive fix however so contact your local vac dealer or get a referral from the Bissell factory for the nearest Bissell authorized dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell powersteamer clearview will not **** up water
Check the heater inside of the handle, it may be clogged and not allowing water to flow. The hose doesn't use the heater and that would be why it flows out the hose.
Apr 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
258 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
