Question about Kitchen Ranges
My Frigidaire gas oven won't light, what should I do?
My frigidaire oven won't light
Posted on Feb 07, 2010
3 Suggested Answers
  • 341 Answers
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
Posted on Jul 18, 2009
mgprice
  • 744 Answers
SOURCE: Frigidaire Gas Range--Oven not heating
Hello, Yes your igniter is going to be bad on this one...even if you see that it lights the igniter is old and should be glowing a brillient yellow..I would replace the igniter and you will be good to go. If you have any questions or concerns please feel free to comment. Good Luck! Mike
Posted on Aug 17, 2009
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven light won't come on
turn light switch off !! then take bulb out, then look inside socket u will see center little pin, with small flat head screwdriver gently pries out so that when new bulb goes in u r sure to make connection.
Oct 11, 2012 | Frigidaire Gallery 30" Self-Cleaning...
My oven won't lite and there is no gas smell
either the gas valve is bad or the ignitor/glow coil is bad,most likely the glow coil as gas valves don't fail,but both are in a series circuit and rely on each other to operate and light the flame,check both with a continuity tester and if they show resistance they are good,but get the specifications on how much resistance on the gas valve and NEVER connect the gas valve alone or directly to 120 volts a.c.
Aug 21, 2011 | Frigidaire Ovens
My oven stopped working on my frigidaire range. All top burners still work. What could be the problem?
Can you clarify a couple of things for me please:
Is this a gas hob and gas oven, or is the oven electric?
If it is gas, does it have a pilot light? (and is the pilot light on?)
If gas, does the oven light for a moment and then go out or does it not even light?
Jul 10, 2011 | Frigidaire Ovens
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
Frigidaire oven
Your oven valve won't open all the way
Aug 15, 2007 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
660 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
