Question about SanDisk Sansa e250 MP3 Player
Computer is not reading the Music Files
At home, my computer can read the music files .wma but when I plugged the usb at my work place, it only reads the folder but the 404 songs that I have in there can't be read. Why is that?
  • 8,596 Answers
Re: Computer is not reading the Music Files
Networked computers treat mp3 players like hostile antibodies - configured not to read wma's apparently
Posted on May 25, 2008
0 characters
3 Points
How can I download music from computer to Mp3 player
1. Get on Computer 2. Plug in USB cord in the USB slot on the main computer. 3. Open My Computer and it should say on the side there is a USB device or the type of MP3 players name. 4. Open up another My Computer window. 5. Goto the location your music files are located and make sure both windows are visible on the screen. 6. Drag your music files to your MP3's music file section. Sometimes the music files wont work so first try the WMA (windows media audio) file first. If the WMA files dont work on your MP3, convert them to MP3.
Jan 06, 2014 | Craig Cmp616f Mp3 Player
Creative zen micro won't read my music
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :-
Jul 16, 2012 | Creative Labs Zen Micro MP3 Player
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Authorized Finis Dealer
Get Swimp3 Deals at
May 21, 2010 | Finis Swi MP3 Player
Files show fifferent on computer
Some of the files are not being read to do incompatibility issues.
- if there is a specific folder music should be in, put them all there (this includes subfolders)
- if it only supports certain lengths and characters, rename the mp3"s not being seen
- try recoding the files if they don't work. maybe some are different and are unsupported. An example would be a wma file if your mp3 player doesn"t support the wma format.
May 20, 2010 | Sony Network Walkman NW-E005 MP3 Player
Coby MP-610 MP3 Player
You need to use MP3 or WMA files.
Sep 07, 2009 | Coby MP-610 MP3 Player
Istage mp4 player
buy one that actualy works
Jun 15, 2008 | Acer MF35 MP3 Player
Music from Itunes (from cd's uploaded to computer) to Sansa
The Sansa Clip cannot read AAC file format (which is the format used by iTunes) - convert all your AAC files to Mp3's or WMA's
Jan 25, 2008 | SanDisk Sansa Clip MP3 Player
Won't recognize music files
My Sansa only reads mp3 or WMA files, not mp4 files.
also, i have tried three different computers, and all of them recognize (or NOT) my player differently....
Jan 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Will not read the sandisk card
When RCA first came out with the Lyra series the only way to get music1.gif onto the device was by using musicmatch jukebox that would convert your mp31.gif file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support and find your player and download the firmware and drivers (if needed) upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma1.gif at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Oct 25, 2007 | RCA Lyra RD1080 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
