SOURCE: How to remove old Mueller (1951) wall mount faucet
Faucets are installed from behind the wall and there fore you will need to either cut the sheetrock on the opposing side or cut part of the tile out on the front to gain access to the valve. It is better if you come in from behind as you can build an access panel if you ever need to gain access again.
Thanks for using Fix Ya.
SOURCE: how to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sink. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way.
Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging.
Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well.
Step4Repeat Steps 2 and 3 for the cold water supply line.
Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line.
Step6Turn on the water supply and test for leaks
SOURCE: i need to hook up 3/4 cpvc water supply line to water meter
I went to Home Depot for the same reason.Ended up getting a brass fitting with a cpvc insert that excepted the cpvc pipe to be glued into brass fitting once it was screwed in place.Came out about a foot then used a coupler to join both cpvc pipes so in the future I can replace meter without cutting pipe.Im not a plummer just a home owner who cant afford one so I dont know if I did it right but it works.
SOURCE: The pull out water line to the brass europlus II
yes, i replaced my american standard hose it was a lot of work to get new hose down the facuat body, you can go to their website and get part number and price for hose. my amercian standard hose was about the cost of a new facuat, so i adapted a differebt make to fit with reducers and nipples.
SOURCE: How do I get an
I went to OSH hardware. I unscrewed and took the portion of the faucet- that the hose from the steam cleaner was to fit into and I took the hose right into the store. I just bought my unit at the thrift store. Works great. I love it!
