Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
I cannot turn the handle to backwash
Pressure washers cleaning around the pool got a whole lot of small river rock in the pool. The creepy-crawly must have picked them up and they have jammed the handle. I took all of the screws out but could not pull the top off to try and clean. Is there something holding it besides the visible screws? I appreciate any help.
    Scholar:
  • 34 Answers
Once you remove the screws on the top of the valve there is nothing preventing it from being removed.
Since there is a distinct possibility according to your account that there is small rocks or debris in the valve you may need to apply additional force. One method that has worked for me in the past has been to use a flat head screwdriver or putty knife and pry around each screw hole. A slight twisting motion with a thin screwdriver is usually enough to help break free a valve top that maybe packed with sand or other material. It may help to remove the valve from the tank first, and spray water into each port prior to your attempt to remove the valve top; The water may help dislodge any deb-irs obstructing disassembly.
Posted on Jul 23, 2009
Why does my creepy crawly loose suction after ten minutes
you may have a damaged diaphragm in the crawly itself. they often develop holes and will react as you describe. if this is the problem, it is a nice cheap fix.
Dec 01, 2015 | Pool & Spa
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
I have a waterco pump and sand filter and can't get a high flow thru the pump to operate the creepy crawly
see if it works on recirculate if it does change sand or backwash if suction based and you have multiple inlets close the ones not being used if it is connected to a pool return close the other return valves or plug them while cleaning
Sep 14, 2015 | Waterco Pool & Spa
At what pressure should you backwash a sand filter
The back pressure at which it's time to backwash a sand filter is about 6-8 psi above the baseline pressure of a clean filter. Just after following the procedure to backwash and rinse your filter, check the sand filter's back pressure at the time you return the pump and filter system back into filter mode. This is the baseline pressure of your clean filter. As the filter gathers particulates from the pool water, the back pressure will rise over time, as indicated on your pressure gauge. Once the pressure reaches 6-8 psi above the baseline, it's time to backwash.
Some advice: Don't assume the baseline pressure will remain the same for your sand filter. The baseline pressure will change over time and when the sand media is replaced. Typicallly baseline pressure will go up slightly over a season due to captured particles that are difficult to backwash out. Use of a filter cleaner will help remove these captured particles.
More advice: Even with the use of filter cleaners and proper backwashing, sand media will not last forever. The constant water flow and movement of particles in the sand over time shears the surface of each little sand grain. Like a river flowing over rocks, over time each sand grain surface is smoothed, and thus its effectiveness for capturing small particles is reduced with ongoing use. A typical rule of thumb is to replace the sand media +/- 5 years. Some pool owners do it more often, some less. It depends on how long your pool season is each year and how much debris the filter much extract from the pool water.
Jul 16, 2014 | Hayward SAND FILTER, PRO SERIES
My creepy crawly works for a little while then stops.I have 50kpa pressure at the filter
Check for debris or obstructions that could be lodged in the flapper of these pool cleaners. That could be restricting movement and causing the cleaner to stop cleaning. Check to make sure that it is not sticking on the main drain. If the main drain is not closed, missing a grate, or not flush with the pool bottom, it could be sticking. A pool pro would have to do some work to fix these problems (except for closing the main drain).
Jan 13, 2011 | Universal Kreepy Krauly In-Ground Pool...
Recently bought a bull shark creepy from Mica Benoni, and although it does clean the pool ( when it is is facing down), it climbs the walls ( sometimes and falls over onto its back and stays there the...
I have the same problem as well. There is nothing obstructing the the kreepy from sucking. This seems to be a general problem with the bull shark. I have gone to the pool places and without me telling them about my problem with the kreepy they told me what the problem is with the bull shark. My friend has the same problem with his. Mabe there is someone that work for kreepy crawly that knows how to solve this problem.
Jan 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, we have a Zodiac pool creepy crawly pool cleaner which seems to work for a while, then get stuck in the one spot and not move in our inground pool.
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Oct 24, 2010 | Zodiac Pacer Pool Cleaner
Creepy crawly no longer sucks leaves from pool bottom, pump pressure is at 8 only instead of 10.
If pressure is low, problem is before gauge and filter. If pressure is high, problem is filter or piping after filter. In you case it sounds like something is caught in hose or pipes . Could also be something stuck in the impeller. Remove cleaner and hoses and see if pressure goes back to normal. If it does not, check impeller. If it does, something is probably caught in cleaner or hoses.
Jul 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Creepy crawly tangles
You will need to take the hoses out and lay them flat in the sun for a day or two and while you do this take the head to the store and have them caeck the swivel at the top of the mast head. Good luck.
Mar 30, 2010 | Pool & Spa
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
90 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
