Question about Fuji Finepix F50FD Digital Camera
Formatting sd card
I inserted SD card and followed formatting procedure, but the screen goes black and the camera just freezes.
  • Steve Grezoux
    Steve Grezoux May 11, 2010
    Have you tried it with another card? How about without a card, whereby you would be formatting the internal memory? Will it take photos on either the internal or card memory?
That happened to me too, bummer.
Posted on Jan 14, 2008
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Fuji Finepix F50FD Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
