Question about Sony Cybershot DSC-H3 Digital Camera
Error message "use compatible battery only"
I am using the battery that came with the camera....it has been flat for a while and i just recharged and now this error message is coming up??? not sure why..
Cheers.
  • 14 Answers
I had this same problem and also have a post on fixya on how to fix it and many ppl have emailed me saying thanks. it worked for me and many others. i'll sum it up
on the battery is 3 gold or silver contacts they are small squares u need to take a fork or bend a paper clip and jump all 3 together for 3 seconds. after doing this put the battery in the charger for 1 hour and thats it. you can now use it again.
I'll explain. the cause is putting the battery in the charger backwords. this messes up the data in the battery and makes it not work in your camera. The battery has data stored in it so it will only work with your model camera. it gets this data from the charger. Shorting out all 3 contacts on the battery for 3 seconds deletes the data stored in the battery and putting it back in the charger re-writes the correct data. If this worked for you send me a thanks! :-) wiidoctor@gmail.com
Posted on Jun 07, 2010
  • hairdue Jun 26, 2011
    can you make a video
    Problem Solver:
  • 12 Answers
Let the battery discharge.
Then reset the camera.
recharge the battery,
let's see what happens.
Thank you
Posted on Jul 23, 2009
    Problem Solver:
  • 5 Answers
I had the same problem on my cybershot and after cleaning the contact points on the battery and within the camera, it works! I used a clean white pencil eraser and cleaned the points with a twisting motion. Hope it works! I saved myself $91 having to send it in to tech support at Sony - not sure why they don't just tell people to try this.
Posted on Jul 27, 2009
I bought new batteries from local store (one from Walmart and one from Meijer) but both would not work in my Cybershot DSC-H55. On powering up, I get the message "For use with compatible battery...
the camera will only work with li-ion rechargeable batteries
any alkaline battery such as energizer will not work the camera unless you have the very expensive li ion batteries
also as with all batteries that can be recharged , you may have to charge for 4 hours before use
Mar 26, 2017 | Sony DSC-H55 Digital Camera
Camera says battery not compatible
maybe the battery is not the original battery.
you can buy cheap replaement batteries for your digital cameras.
US shop:
http://www.sales-battery.com/digital-camera-batteries.htm
UK shop:
http://www.global-battery.co.uk/digital-camera-batteries.htm
Oct 29, 2010 | Sony Cameras
Upon trying to turn camera Panasonic DMC-ZS3 on, error message appears: system error (zoom). The lens comes out a bit and then goes back in, shutter closes, then lens comes out a bit again, then goes back...
I don't know that I can help you fix it, but I can try. Here are my thoughts... Check the battery first. If it's like a normal battery, like AA or AAA batteries, replace them and try turning it on.
If it's a flat lithium battery that you recharge using a power cord that plugs into the camera, you might want to buy a new one. Charge it fully over night and try powering the camera up in the morning.
You never mentioned what the error message was! So I can't help you there.
Next, you might try connecting the camera to your computer and see if it comes up. Also, check with Panasonic and see if there's a way to reset your camera. Maybe there's a way to do a software reset. Also check to see that there isn't a downloadable software upgrade or patch available. Lastly, you may want to consider Panasonic customer support/technical support, they may be able to better help you diagnose the issue with your camera.
I have a Lumix too. I have an DMC LZ10, my daughter has a DMC TZ3. They're similar in many ways, and yet they're different in many too. Mine uses AA batteries, hers uses a flat lithium rechargeable that uses a power cord. The internal software is pretty much the same (sort of). Enough so that I can work the settings on hers without having to reference the manual.
As a computer tech, my first impressions are that you're having either power issues, or software issues. Eliminate the variables. Start with power and work your way out from there. If it behaves the same with any battery, you've eliminated the power issue. Now it's software. Simple enough?
Aug 03, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I put new batteries into my nikon camer after I was alerted with the ''battery exhausted'' screen. It now won't turn on.
Make sure you are using rechargable batteries. Normal batteries are not strong enough. Try using either rechargable Lithium Ion batteries, or rechargable Nickel Metal Hydride (NiMH) batteries. These are much stronger and should give you a good battery life.
Feb 27, 2010 | Nikon COOLPIX L100 Digital Camera
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Compatible Battery error message
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
Sep 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
I have had my camera for over a year now without a problem. It is a Sony Cybershot 7.2 Megapixels. Everytime I turn it on a black screen and the message - "For Use with Compatible Battery Only"...
Hi
There is a sentence which i cannot figure out the your wrote in your initial description of your poblem. I think it is meant to be the error message you are getting here is what i read as part of
""For Use with Compatible Battery Only&quot"
Can you try and post it again. From your response i still have te suspicion it could be the batteries, but your error message will help.
Regards
Jul 16, 2008 | Cameras
Rechargeable Batteries
This is a triky one. Most cameras will work with rechargeable batteries. If they don't work the most probable cause is this: a normal battery has about 1.5 V nominal charge. Because you use 2 of them you get 3 V nominal charge. Most rechargeable batteries have about 1.21 - 1.25 V like yours. This is given by the technology type used in their construction. However 2 1.25V batteries will result in 2.50 V at nominal charge and some cameras woun't go whell with the 0.5 V difference. You should try other types of rechargeable batteries, maybe some of them will work, but it is recomandable to do that before you buy them, so like I said, it's a triky choice. Try to go to a digital camera shop, they may sell rechargeable batteries more compatible with your camera.
Mar 11, 2007 | Fuji FinePix A500 Digital Camera
Sony Cybershot DSC-H3 Digital Camera Logo
336 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
