Question about Maytag NMPEB08F2A Air Conditioner
HOW DO I RESET WATER AND FILTER ALARM SO I CAN GET IT RUNNING AGAIN. CAN'T FIND THE MANUAL. Mike Wells
I've used mine for 6 years. Works great. You really need to attach a plastic tube drain line on the top (middle back) drain valve and leave OPEN, and vent it outside. Let it drain when it wants. Otherwise, you'll be emptying that drain pan every 2 days.
Posted on Jul 30, 2009
Our fridge is beeping every time we open it
Check the owner's manual or Google for one. Check to see the interval in which you should be replacing the water filter. Water Filters can usually be purchased where you purchased your fridge or a big box hardware store for around $30-$40. In most cases, you should be able to reset the water filter alarm to clear the beep w/o replacing the filter.
Sep 23, 2016 | Refrigerators
I've changed the water filter on my samsung RS7667FHCB and the red filter is still showing, is there something you need to do to reset it?
Do you mean the RS7667FHCBC? To reset the water filter schedule indicator, press and hold the Ice Type button (bottom center of the touch panel) for 3+ seconds. This is described on page 24 and on page 33 of the user manual. If the indicator doesn't respond, you may need to change the position of your finger so that you press on the contact point of the touch pad. Sometimes, it takes a few tries to get a response from the press and hold action. The manual for this Samsung refrigerator is available from the support page: http://www.samsung.com/uk/support/model/RS7667FHCBC/EU/ . Select the Downloads & Manuals tab then scroll down. Expand the section with the View More link. The current direct link to the User Manual is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=5269131&CDCttType=UM&ModelType=N&ModelName=RS7667FHCBC&VPath=UM/201402/20140225093615091/DA68-02710A_VER0.5.pdf .
I hope this helps.
Sep 17, 2016 | Samsung Refrigerators
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
My alarm for the water filter is beeping? what do i need to do
After you replace the water filter the alarm needs to be reset. Just take the battery out and reinstall to reset.
RJ
Feb 14, 2011 | Culligan Under Sink Water Filter
Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Maytag NMPEB08F2A Air Conditioner Logo
608 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
