Question about Garden
Sthil weed eater will not run when hot?
My two stroke weed eater will not run except wide open when it gets hot , let off the throttle any and it cuts off, then might start back up and run with the choke about half way open after it cools a couple of minutes.
    President:
  • 1,627 Answers
You will need to replace you muffler so the machine can get rid of it's exhaust
Posted on Jul 23, 2009
Weed-eater fl1500le new carb new gas and filter new spark plug getting spark will not start
try priming it 10 times and hold the throttle wide open when trying to start it
Jun 15, 2017 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Carburetor adjustment procedure
    low and hi speed mixture screws
    one adjusts for proper idle
    one adjusts for proper high rpm operation
    turn them in or out to get the best throttle response and proper wide open throttle rpm's
    Aug 26, 2014 | Weed Eater Fl1500 Le Leaf Blowers
    Sthil fs 85 trimmer runs only on starting fluid
    check for breaks in fuel line, check fuel filter.
    May 04, 2014 | Stihl FS 85 Weed Eater
    New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
    I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
    Nov 05, 2011 | Poulan 25CC Gas BlowerVac
    What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
    use - husqvarna , sthil brands high quality 2 stroke oil
    as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
    if you want 2 litres mix put in 40 mils of oil into petrol container
    then put in 2 litres of petrol only and give good shake and fill the blower
    cheers
    Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Engine quits when throttle is opened
    Most weed eaters are two stroke. You have a high and low idle screws on the carburetor. Assuming you have the right fuel mixture. Turn both screws in lightly until seated. Turn two turns out. You should see an h for high and l for low. Stat with low screw first turn in or out until running smooth. Then do the same with high idle screw holding full throttle. Once running smooth in high . Go back check low idle. Should run fine after this. Also check plug see if carbon fouled.
    May 21, 2010 | Craftsman 25cc Gas Line Trimmer
    What is the gas and fuel mixture for a homelite st-185 weed eater
    If it's not been started for that long, ensure that any remaining crud in the tank and fuel lines is cleaned out before even attempting to start it.
    Put in a NEW plug, then mix up some 50:1 mix of unleaded and good synthetic 2-stroke oil (Sthil or similar). This will produce an almost smoke-free exhaust, and won't foul the plug.
    If it does start, be prepared for LOTS of smoke initially, as all the old oil from inside the engine burns off.
    May 12, 2010 | Homelite Mighty Lite Lawn Trimmer
    Garden Logo
    903 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
