Question about Microsoft Internet Explorer 8
Cannot get on line, when i do it don't last very long and then I
Get disconected again. It takes abou 20 tries and they I MAY get on again.
  • 60 Answers
Try using system restore
Posted on Jul 23, 2009
Line across bottom. Appears to be repeat of top of screen.
Try opening the monitor disconect the display panel from pcb power on amd then connect ur display panel. Hopefully display will be remaped when u restart the monitor
Jan 07, 2015 | Dell ST2010 20 inch LCD Monitor
2007 mitsubishi eclipse hard to start after filling up tank. No check engine light on. Bad starter?
Maybe the carbon cannister is loaded up. Try parking the car facing uphill and see if that's better.
Starter is probably OK. Need more symptoms. OR it will be 20 question time. Takes a LONG time cranking B-4 the engine begins to run? That's what I'm guessing.
Does nothing to take the key back out and try it again.Just keep cranking until the engine starts to run.Don't be afraid to crank it for 15 seconds,or so.
Nov 11, 2014 | 2007 Mitsubishi Eclipse
My LG 37LH30-UA has a vertical black stripe aboue 4-5'' thick that goes away after a few minutes. I took off the back but don't see any obvious damage.
Since you mentioned that the fault disappears after few minutes , it seems realtive to a weak component and in all probability it can be a weak electrolytic capacitor. Since you have narrowed the search it becomes still easier to confirm the suspect. So switch on an using a hair dryer gently heat the board which is suspected. If the fault clears, you must cool the board, the use of a FREEZE-IT spray will help to cool the components. Now repeat with specific components or even use a soldering iron on the top of the components so as to heat them individually. If the band clears then the component is confirmed . take time and be extremely careful not to short any component or circuit.
Nov 10, 2011 | LG 37LH30 37 in. LCD HDTV
When I push play there are lines and rolling and I can not control with tracking .
Always best to see if a good clean will do the trick. You can do this yourself better than a cleaning tape, but you can try one if you don't like the idea of messing with the VCR yourself. If you want to do the work, then get some Servisol Video 40 (you can find it on-line). Take the top cover off the VCR - disconect from the mains first. Then spray the servisol where the tape touches, especially the tape heads. If you don't know what to spray then after you take off the top of the VCR insert a tape and press play and watch where the tape touches. Remove tape turn off power and spray. You can use a cotton bud in the tricky areas too. Allow to dry and try a tape. You might have to do the clean again depending how dirty the VCR was. If the VCR lives in a smoke filled room that will make more work to clean it.
If it still doesn't stop rolling then you might have got a head fault.
Aug 20, 2011 | GE VG2040 VCR
My gasline froze last week. The gas unfroze but now my cruise control and ETS systems do not work. Checked the fuses and the appear to be fine. Any suggestions
I don`t think your gas line froze last week. I haven`t seen a frozen gas line in my 20 years in T.O.
Have your car checked for your cruise control and ets.
Feb 18, 2011 | 1996 Oldsmobile Achieva
Yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Aug 27, 2009 | Northstar 6000I GPS Receiver
I winterized my bike last winter. I drained the fuel tank on my zx 750h. ran the motor to empty lines and now i refilled the tank but it wont start. what am i missing. It fired and ran for abou 10 seconds....
try new spark plugs. and for next winter you're better off not draining everything. best thing is add some fuel stabilizer and run it a few minutes once in a while. empty lines tanks and carbs attract moisture.
Jun 11, 2009 | 1990 kawasaki ZXR 750
1999 Volvo s80 fuel line leak before and after the fuel filter
this perticular solution requires special fuel line tools to disconect the clips on the line. I would first locate the leak and determine if the entire fuel line is at fault or if it is just a connection. most commonly a piece of the line has deterieated and cracked and can be readily replaced with an OE part from a local parts house. a fuel line disconect for your vehicle can be gotten at the same parts place in most cases. Just ask the counter person what disconect it takes.
Dec 26, 2008 | 1999 Volvo S80
New filter but now no water
if you take the kick plate off below the doors, on the left hand side below the freezer door youll see a hose conection. disconect that conection and press the water dispenser lever. if water comes out then the line running into the freezer door is frozen. use a hair dryer to warm up the inside of the door behind the dispener. it takes about 20 to 30 min but once thawed the dispenser will work again
Nov 19, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Frozen screen says: refresh database
tyr taking the battery out or try holding the power button and the play button at the sametime for 20 secs.
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
