From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
can any one help, Our Dyson Animal vacuum has plenty of suction when it is upright and
the attachments are being used off the hose, but when the handle is
tipped back to begin cleaning carpets the beater head is getting no
suction. As the handle is being tipped back you can hear what sounds
like a flapper valve in the body of the vacuum opening and then all the
suction just goes away.
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
so the red hose isn't connected to a part on the vaccum so like it is connected to the connester but not to an opening just above the beater bar, this is the only idea i can supply you with. good luck, maybe i got lucky and helped you out.
