Question about GE (PSS26MSRSS) Side by Side Refrigerator
The only thing working is the light.
The fans do not come on nor does the compressor, it is an old (1985)kenmore side by side.
  • tinmac13 Jul 23, 2009
    I tried to bridge the thermostat but that did not work,so I tapped on thedefrost timer and it kicked on.
    Problem Solver:
  • 12 Answers
The thermostat is the one that regulates all the operations in this side by side.
Bridge it and let's see if the appliance works.
Thank you
Posted on Jul 23, 2009
  • jacobotz Jul 23, 2009
    Ok, I did not know it was a frost free model.
    We'll you have repaired it.
    Change the defrost timer is very cheap.
    When the timer goes on, it disconnects all functions and only the defrost resistance works in order to disolve the ice in the evaporator.
    Congratulations!!! you have fixed it.
Freezer not freezing its bout 12 years old do u think a shot of frioen will work
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem.....
May 09, 2011 | Kenmore Side by Side Refrigerator
Our 10 year old just stopped cooling. lights and fan work but no cold air.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 27, 2011 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side, fan on, lights on, compressor hot, no cool.
You probably have a bad overload/relay on the compressor . The piece which plugs onto the compressor . Or a bad fan which cools the compressor (condensor fan motor ). Also check the coils to make sure they are clean . Would need the first 3 numbers before the ones you gave , to be able to give you the part number for the o/r .
Jul 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator not working
Hi!!! Go to the back of the frig and see if the compressor and condensor fan motor are working.If not then you have a bad current relay.easy fix.its located in the compressor where the wires go into..Good luck.Heres a picture of your current relay..
Jan 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Not cooling, ice on evap. coil
After ten years, the defrost coil may be bad. That will allow the evaporator to ice up. Find the defrost timer, check it out first. Some have a manual control.
Dec 21, 2008 | Kenmore 53642 / 53644 Side by Side...
Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Refigerator not working properly
the compressor is out of coolant/freon.u should not run it if the compressor is too hot to touch
Aug 02, 2008 | Kenmore Elite 21086
Kenmore Not cooling
there are 2 common problems with this frig. one is the defrost timer getting stuck in defrost. in this case all lights will work but no fans and no compressor running. the other problem is the relay overload on the side of the compressor but if this is bad the fan inside the freezer will be running. sounds like defrost timer
Nov 20, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
