Question about Kitchen Ranges
GE oven door
I need to dismantle the door on my GE oven. It has a lot of gunk in it from using the self cleaning oven feature. It looks awful and needs to be cleaned in between the glass on the outside and inside. Help!!!!!!!!!!!!!!!!!!!!1
  • peckerhead Nov 20, 2007
    Thanks for the tips. The oven was not very dirty. I do not use it very ofter. Reason for cleaning was that a realtor is coming to check out the house and I wanted everything to be perfect. Instead, now I have a nasty looking oven! How the gunk got between the door glass is a mystery.
  • Anonymous Dec 02, 2007
    I want to know how to clean my oven door glass from the inside, I have tried and cannot get the glass out to clean it
Go to the Dollar Tree and get you a $1 bottle of Awesome. It is truly a wonderful cleaner. I used it to clean my oven door when I rented my house out.
Posted on Sep 06, 2009
  • 833 Answers
First, determine what this gook is. If it is grayish, it is ash and can be removed with a rag and plain water. You'll always find ash as a byproduct of the cleaning. If it seems to be oven grease and is located in the gasket or gasket area ONLY, get some WD 40 and spray it on the gunk. Let it loosen up and remove it with a rag. You may need multiple applications. If possible, follow up with a soap solution to remove as much of the WD 40 residue as possible. Note, this may cause some smoking when the oven is next cleaned. Be sure to ventilate the area well while using this or any other solvent. Do not use the solvent on glass, it may discolor when heated. Use a standard glass blue liquid glass cleaner or water. If the glass won't clean easily, you may use a WET mild abrasive pad or steel wool VERY as not to scratch the glass. Follow up with a dampened rag. Anything you leave on the glass will be baked make it clean! You may also use this procedure in the gasket area on the porcelain. Porcelain is a glass-based paint. It should not be scratched. Be patient.
Be aware that if you take door apart that the door is counter balanced. Removing a significant amount of weight by taking off pieces of the assembly may cause it to slam closed. Each of the two thicknesses of glass are mounted separately. Usually, there are some kind of clips holding the glass. Note that there is often fragile insulation inside the door. Avoid touching it or breathing in any dust it may emit. You may need a second pair of hands to align the door front and the bolt holes when re-assembling.
In the future, do not wait too long between cleanings. Use a rag to remove heavy spillage as soon as you find it, don't wait for a cleaning cycle. If your oven is very dirty, use a 3 hour setting or longer to finish the job if you have goo left in your oven after the cycle.
Posted on Nov 20, 2007
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ... > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ... > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
I have neff double oven ,only had it two weeks and the top oven which i use the most looks filthy- i have had it on self clean at least three times but the floor of oven is burnt on and looks awful. W
Self-cleaning ovens are not "squeaky clean" after the cleaning cycle has run. Any spilled food or debris in the oven before it cleans will be left behind as ashes, soot, etc. and you will need to wipe it out with a damp cloth afterwards. If the residue is black and sticky then the cleaning cycle isn't running at a high enough temperature. Please refer to the manufacturer's instructions to make sure the cleaning feature is working and being operated properly.
Nov 20, 2014 | Neff Ovens
White residue left after using self cleaning feature - I can't remove it with soap and water and elbow grease. What would work? This looks awful!!!
The residue your seeing is the remains of whatever was left in the oven when you decided to creamate in. Grease, food, etc was basically turned to has and then powder coated into the metal. Bit of advice for the future though, avoid using self clean mode not only for the scenario you have, but for your bank account as well. The temperatures the oven reaches in self clean exceed that of which the oven cavity can handle letting heat pass upward, usually damaging the lock mechanism for sure, as well as the control board and touchpad.
Apr 23, 2012 | GE Profile JT952 Electric Double Oven
Self-cleaning feature
Check your owner's manual, but most self-cleaning ovens should not be cleaned with chemicals. The finish can be permanently damaged. You might try running the oven through the self-cleaning cycle more than once. It will take some time. Make sure the room is ventilated properly since the cleaning cycle produces a lot of heat.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 | Ovens
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
We have a ge self-cleaning radiant range. I accidently spilled hot grease from steaks when I was removing them from the broiler. The grease dripped down inside the glass on the front of the oven. Is...
If you are saying that the grease got in between the layers of glass (lamination), then you will have to disassemble the door, clean the glass, and reassemble. I haven't done this job on your particular model, but have on others and it is a tedious & time consuming task.
If though the grease is just cooked onto the inner surface of the glass on the oven door, you could use a single edge razor to scrape the gunk off (being extremely careful not to flip the blade causing you injury), as you would ice off a windshield with an ice scraper. There are handles made to keep the blade secured while using it (making it less likely to flip and injure the user).
Apr 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
425 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
