Question about Whirlpool WFW9200S Front Load Washer
The whole drum wont turn when loaded fully, will turn sometimes when only a few items???
    Scholar:
  • 61 Answers
How old is the machine? if its around 2-3 years old it could be the motor brushes are starting to wear and need replaced hence the less power from the motor when loaded. check the brushes of so these should be around an inch long when first installed
Posted on Jul 23, 2009
Severe vibration/noise during spin cycle. What could the problem be and how do I fix it?
if the machine was run severely out of balance (rugs) you'll need to get a look in the back up near the top with a good flashlight , this involves unhooking power and hoses and turning it around , you may have broken a drum suspension link , this device (three) keeps the drum from contacting the shell , if its true and its allowed to run this way you will brake off water hoses on bottom of drum and water will runout on floor
Feb 09, 2016 | Bosch Washing Machines
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
Apr 20, 2011 | Zanussi FJS1225W Front Load Washer
HI MY AMANA DRYER HAS A HARD TIME STARTING AND AFTER A FEW MINS. STOPS
I am a little puzzled! Normally the difficulty is with startup rather than stopping after starting. Are you sure that the drum actually turns or maybe it just sounds like it is turning? If it never actually turns then it is probably the belt or the motor. You can make sure by placing only a few items in the dryer (try a couple towels or different colors) place the towels inside, (pay attention to where they are) begin the cycle, open the door to see if the towels have changed position. If the drum has been rotating then try adding a few more items to see if things change.
If the drum does not turn at all it maybe the drum belt. If, as you increase the load, the drum has difficulty starting then it is probably the motor or a control circuit. Hope this helps...Good Luck. Douglas
Jan 28, 2011 | Amana Dryers
My white night wont turn with full load,but if we lighten load it turns?
these are the items/parts:
1) belt may be stretched, examine belt for cracking and if it looking old replace
2) idler arm/pulley may be wore out, examine
3) drum rollers/glides may be wore out (second link)
4) motor may be going out
for the belt,idler arm/pulley and motor:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
drum roller/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 16, 2011 | Zanussi TD4100W Electric Dryer
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Creda drier drum will not rotate when fully loaded
The belt could be worn or bad or the tension spring is to loose and not keeping enough tension on the belt. When loaded to max belt just slips and doesn't turn the drum.
Dec 16, 2009 | Sewing Machines
Ive got a hotpoint electric dryer that intermitantly blows hot air..in other words sometimes it wroks while other times dosent blow that much needed hot air to dry clothes..ive tried different things like...
Sounds like the drum is not turning under heavy load.this is a common problem with dryers but usually easily remedied if a competent diyer. first check the theory by putting in big load and see if drum turns. if not then replacing capacator should cure it.
Nov 06, 2008 | Dryers
Drum turns but not when it is fully loaded
Do you hear a loud hum when fully loaded? Or does it go away when empty?
Sep 20, 2008 | Amana DLE330RAW Electric Dryer
Whirlpool WFW9200S Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
