Question about Samsung SCX 4200 All-In-One Laser Printer
Add Paper / PC Print pending message on LED message
Add Paper / PC Print pending message on LED. However, have added paper at all levels. Where is the sensor that's telling the printer it's out of paper when it really isn't? Thanks.
  • Anonymous Mar 17, 2014
    message "add paper" but there is paper in the printer
    New Friend:
Pls help to replace this unit plz
Posted on Dec 08, 2012
    President:
  • Samsung Master
  • 1,447 Answers
It is problem your printer paper sensor it was broken lever or open
Posted on Jul 23, 2009
  • Sazeed Computer
    Sazeed Computer Sep 12, 2009
    recording paper not sense in your printer
Every time I try to print to my Dell 3110cn printer, a message pops up stating "Load Tray 1 024965 Executive" Paper tray is full and inserted correctly...what do I need to do to make it print?
I would try two steps:
1) Check the "pending documents" for your printer and make sure the printer queue is empty - delete any pending document.
2) Check the printer settings and make sure the default paper type is not set to "Executive". You may also check this in the paper properties of the document that you want to print.
Apr 29, 2014 | Dell 3110cn Laser Printer
The printer says Load MP feeder B5. how can I fix this.
Several options here:
1st - cancel any documents in the print queue. and print off a report of some kind via the menu button on the machine. if that prints correctly then it either a software/ print driver setting issue.
2nd - If that prints out correctly open up a text pad/ notepad and attempt to print that if the message pops up it's very possible the paper handling has been miss-configured within the print driver.
Now if the document does print out fine, the original document you were attempting to print is set to a B5 paper size. If that's the case pending on what program you are using you will have to change the paper size to you choice of paper your using.
3rd - open up the paper tray and confirm it's set to letter or legal pending what type of paper you have in the tray(not the manual feed tray). I highly doubt it's the tray however as B5 setting would not allow any type of normal paper to be loaded.
4th - on the machine hit the menu button -> paper menu -> confirm that the paper type/ size and source are configured correctly.
Link to the user manuals for this machine : click here
Oct 19, 2010 | Lexmark T632 Laser Printer
Chris asks. My Samsung SCX-4200 is showing ( add paper no paper and PC print pending ) on the led
Check and Cause:
1. Deformed paper sensor actuator or faulty sensor.
2. SMPS PBA or Main PBA is defective
3. Faulty cables or connectors.
Solution:
1. Replace the defective actuator or sensor.
2. Replace the SMPS PBA or MAIN PBA as
appropriate.
But better - take MFP to authorised service center
Nov 30, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Kodak Easy Share printer dock will not print pictures
If you have too much paper in it, the paper will stick and you will get a false reading.
Aug 09, 2009 | Kodak Easyshare Printer G600 Thermo...
The printer keeps printing the same page then come up withcheck paper size then flashes change paper size, I have turned everything off and turned it back on again and it just prints the same page and...
Hi..
I think your there is a pending command to print, even if you have turned your printer on and off, it will print already because the pending printed papers in your computer is automatically printed, you need to check the printer status in your computer. just click start then all programs, then click printers and fax, now you can see now the printer icon just double click that, if you can see a pending printed, just right click and cancel, if you can not see the pending you printed document, you need to restart your computer so that all the pending command will turn out.
Good luck
Regards
PCmania
Jul 09, 2009 | Canon PRINTER/COPIER/SCANNER All-In-One...
PC Print Pending Message Won't Go Away
Have you tried to delete the print job from the computer? After that is done reset the printer by turning it off (30 sec) then on again. If that doesn't work take the paper out and start cleaning your printer with canned air, Q-tips and a cap full of water.
Dec 10, 2008 | Samsung SCX-4100 All-In-One Laser Printer
No paper
Tracoi, first you need to clear pending prints. If your using WinXP, click the start button slide up to & left click on Printer and Faxes. Click on your printer & clear/end prints pending. Power off your printer & look in the printer where the paper path is. As the paper passes through the printer, it pushes against little black sticks that wobble back and forth to trip the different sensors. These little 'flags' usually kind of stick up in the middle of the plastic along the paper path. Look over the whole paper path and find all the little flags and make sure they're all moving freely. Sometime they get knocked out of place. You only need one to mess up the printer function.
Luck!
If this did not help just let me know & we'll try something else.
Mike
Apr 19, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Blinking Light
uaually the LED blinnks when there is no ink or when it runs low on ink. But since the LED is kept there to indicate any error happens to the printer.... 1. So I suggest that you should take out the printer cartridges and check all of them....shake well before you put it back. Now open Control panel - printers and fexes - right click HP 5550 - Properties There should an option to see the ink levels. If you can see the ink levels....it means that printer can detect the cartridges. Now the printer LED should be turned off. If the above doesn't work, try this; Check the printer que .. if there are print jobs pending, the LED will blink. Delete the print jobs, and restart the machine. This should solve your problem.
Oct 02, 2007 | HP DeskJet 5550 InkJet Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
1,044 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
