Televison & Video Logo
Posted on Jul 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a polaroid 42 inch flat screen and the screen is solid blue when i plug my cable in it is black I can here sound but no picture it is a 2007 module tlx-04240b
Anonymous
Level 3:
  • Master 616 Answers
  • Posted on Jul 23, 2009
Anonymous
Master
Level 3:
Answers
616
Questions
0
Helped
144657
Points
1638
Make sure all the connections are correct, a "blue" screen indicates no-signal, black indicates some type of signal is getting to the tv. good luck Julio [email protected]
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Our 42 inch led flat screen went black we still have sound but no picture. Could this be a fuse problem?
No! The power supply board is working, you have sound but no picture. the problem appears to be in the high voltage module, if the inverter transformer has failed the screen would go dark. this will require a tech to troubleshoot the problem.
Baird 42 inch LCD tv turns on but has black screen but no picture or sound
I have a 42 inch baird tv it will show the blue screen for a couple of seconds and then there's nothing just a black screen
2answers
Sound but no picture
Ur LCD inverter board is dead.This LCD inverter board,help to get the LCD screen,to have backlight go throught the Tuner board to get the cable or free air tv signal to get a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
2helpful
I changed the capacitor on my polaroid lcd tv. It
Hello
Most likely when you disassembled the unit to replace the capacitors you unplugged the screens data cable. When you replugged this you probably didn't get it plugged in correctly or bent some pins.
Good luck
1helpful
4answers
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
I have the same problem
I didn't but the control box,but found 2 caps inside it on the power board and replaced them both 10uf 450V.It fixed my problem
2answers
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
