Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Marco gas firplace
I recently bought a house w/ a Marco gas fireplace. There is no owners manual and the company has gone out of business. I have never used a gas fireplace, so I have no experience w/ this. It has a direct vent going out through the roof, so it is not one of the Marco models which were recalled. There is a key and a valve on the wall that it fits into, but I don't know if there is a pilot that I need to light. I would really like to get a hold of an owners manual, but short of that I would like to know how to turn it on. Can you help me?
  • 5 more comments
  • jerryknw Dec 04, 2007
    Thank you--that did it!
  • inabind9 Dec 17, 2007
    Hello, I have a similiar problem. It may sound silly, but I do not know what position the side air intake lever should be in when I operate my gas/wood fireplace. The external opening is shielded, so I don't know if the vent is open with the lever up or down. I can't feel any real difference in air flow in either posistion, but I have been told it is not a good idea to operate the fireplace with the outside air intake closed. So my basic question is-----standard lever installation with up=open or up=closed?
  • Anonymous Sep 01, 2008
    need owners manual
  • Karyn Carpenter-Diebel Oct 23, 2008
    I have the same issue with finding information on this fireplace and replacement parts. I do have a manual for the 792777 bm 36 hc model. I trying to find out what is needed to covert this to a regular wood burning fireplace. If any one has information i would be grateful. I do know though if you do not have a model number it can be located inside along the bottom lip or top lip that just what i have read
  • dobroao Dec 04, 2008
    We bought our first house. It has Marco fireplace, model 792775B. We never had a gas fireplace and don't know how to use one. The Marco company is out of business. Does anybody have a manual to it or know how to safely operate it? Thank you!
  • Anonymous Dec 21, 2008
    Marco model # 7927750. I have no manual and need lighting instructions.
  • Anonymous Jan 09, 2009
    we bought a house in March with a Marco gas fireplace with no manual. The pilot light is lite but can not get the log to lite. Can you help us. gnenostervilli@aol.com
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Posted on Jan 28, 2009
I also have a Marco fireplace with what sounds like the same setup as you. I've been digging for an owners manual myself for allowed clearances around the fireplace for wood mantles and such.
If the fireplace has a key valve it DOES NOT have a pilot. My fireplace has gas logs in it and I simply light a long match (or use one of those long necked stove lighting wands) stick it between the logs and turn on the gas. Make sure that the match doesn't extinguish as you poke it in between the logs (it may take 4-5 seconds before the gas lights up.) Also make sure that your flue is all the way open when using gas as your fuel.
Posted on Nov 27, 2007
Lennox bought out Marco. Google Lennox gas fireplaces and you should be able to find a technical support number somewhere. Here's a link with the recall info...it has a 1-800 number on it. Good luck.
Posted on Jan 01, 2009
  • FMDude Jan 01, 2009
    Sorry I didn't iclude the link above. Here it is
    http://www.cpsc.gov/cpscpub/prerel/prhtm...
To Kfcarpen:
Do not try to convert your Marco direct vent gas fireplace to wood burning. Neither the firebox nor the vent system were designed for wood. Trying to burn wood in this unit will create an extreme fire hazard. If wood burning is really desired, replace the entire system.
Posted on Nov 15, 2008
    New Friend:
I MOVED TO A PLACE THAT HAS MARCO WOOD BURNING FIRE PLACE MODEL DF36S AND I NEED TO KNOW IF I CAN MANTEL MY T.V. ON TOP OF THE FIRE PLACE ON CHIMNEY.
Posted on Nov 02, 2014
I have a MAJCO gas fireplace model # G36DVp1. It needs replacement seals. Need help in finding them.
Posted on Dec 17, 2010
Sometimes a fan is controled by a temperature switch , AS WELL AS a on/off switch! so that only HOT air is blown out of the heat exchanger. What I am saying is that the fan may run only if: 1)switch "on" AND 2)temperature in heat exchanger at say 85* f.
Posted on Mar 15, 2010
I also bought a house that has a Marco model 792862B fireplace. It is made to burn wood and it has a gas lighter. I have decided that the way to light a fire is by putting wood on the garte over the gas lighter, then hold a long match or butane lighter (one of those long ones) to the gas outlet while turning the key that fits in the hole near the fire place.
Now, I too want an owners manual because I think the unit is made to provide some sort of heat through the vents that surround the firebox. I find a little lever on the right side of the firebox about half way up the front. It can move up and down about 45° and it looks like it might control air flow to the vents. However, I think there should be a fan installed somewhere inside the unit. I have a wall switch nearby that does not seem to do anything. I wonder if this is the switch for the fireplace fan and if so, how do I operate it so it works as a heat source? Or maybe there is some problem that I need to correct... At any rate, I would dearly love to have a manual and technical details about this unit.
Thanks
Posted on Nov 02, 2009
  • 102 Answers
You could have a switch that looks just like a light switch that controls the ignitor just like a stove. Check for it nearby. Turn on gas and then flip the switch. If no switch then use a match. Try not to turn on the gas wide open just do it gradually.
Posted on Dec 04, 2008
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Is the Marco Fireplace 7792778E a fireplace or a fireplace insert?
Apparently the Manufacturer is out of business but there is a MARCO Distribution company. Call them for info since internet searches are failing.
call Marco Fireplace Distribution at 818 764 3366
Jan 02, 2015 | Heating & Cooling
I recently bought a house w/ a Marco gas fireplace. There is no owners manual and the company has gone out of business. I have never used a gas fireplace, so I have no experience w/ this. It has a direct...
Hi the key turns the gas on there is a arrow saying on /off turn to on .
remove front panel should lift up then down look for large metal plate should have lighting instrutions on them?
if not you will see a gas valve 1 maybe 2 black knobs look for the one with off pilot on , look for small knob red or black this the spark igniton , okay turn first knob to pilot and press in and hold in depress spark knob keep doing this untill pilotlights there might be air in the line so this might take time , when the pilot lights HOLD BUTTON IN STILL for 30 secs then release turn knob to on pilot should stay on if not do again , if stays on turn up thermosat if fitted or turn power on at switch you will have to find that will be near fireplace the other black knob turn sthe flame up and down hope this helps
Feb 09, 2010 | Leisure HOMEPRIDE Electric Fireplace...
I recently bought a house w/ a Marco gas fireplace and there is no owners manual. I have never used a gas fireplace, so I have no experience with this. I would really like to get an owners manual, but...
www.macro-fireplace.net is the manufacture's website where you can request a manual for free.
I haven't located any others but I will keep you posted if and when I find one.
Nov 08, 2009 | Leisure HOMEPRIDE Electric Fireplace...
How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Dec 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
Oct 19, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
15,085 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
