Question about Kenmore Ovens
Oven takes to long to heat up, atleast by the indicator light
    President:
  • Kenmore Master
  • 1,922 Answers
Check for 240 volts at range plug in( if you only have 120volts and you have fuses one of them is open,this normally wont happen with a breaker if tandem or two single poles w/tie handle),if you have 240 volts then w/range unplugged examine element,it may have a "hot spot" in it where its going bad,sometimes its discolored there and may be pitted youll be able to break it if its pitted/order a new element from "Appliance Pro's" prices service,shipping are great and reasonable
Posted on Jul 25, 2009
Oven doesn't heat up and no light symbol shows up on the indicator panel.
it sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Nov 03, 2012 | Bosch Ovens
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Nov 28, 2009 | Ovens
6200.5 fan works but no heat and light remains off
I suspect that from the symptons you describe that the fan oven element is faulty, the other possibility is that the thermostat is faulty, even if the element is faulty, the thermostat indicator light should come on.
Please rtate my solution.
Thanks.
Nov 08, 2009 | Kuppersbusch EEB62001 Electric Single Oven
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 | Ovens
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
