Question about Kenwood Car Audio & Video
My subwoofer keeps hitting but its not even hitting with the song its just a constant tempo, i just hooked it up and it all worked beforw but i dont know if i have a wire crossed or what
Check your rca connection....if its touching any other wires....remote, power, ground this will cause unwanted audio signals to travel through your signal lines....also check the inputs on this amp where your signal lines plug up...this might be loose
Posted on Jul 23, 2009
How to hook up the wires for aux through phone which wires go where, there are so many colors
I dont think a cell phone can push enough juice for household speaker or stereo system...can it? Its why we have to buy accessory speakers with amplifiers in them.
Not 100 percent sure tho
Sep 09, 2014 | Audio Players & Recorders
They speakers, when they hit hard they make this odd... smacking sound.. Also on just like.. eminem songs and some rock songs that I listen to whenever the subs hit the vocals get distorted, but when I...
Well it sounds like you need a mono block amplifier for the subwoofers. Subwoofers are ment for low frequency. If you try to run regular audio through the subwoofer the sound will become distorted at a high volume. If you have a crossover on the amplifier try putting it on LP. Also do not exceed the RMX rateing on the subwoofer because if you do they will also distort. If you try adding the mono block on to it and it is still doing it you may also be running to much power to the subwoofers.
Jun 13, 2011 | Alpine SWS-1043D Car Subwoofer
The Simmons SD5K keeps spontaneously playing songs, even when all I want to do is play my own stuff with the metronome! I turn on the metronome, set the speed, hit the pads a few times, and the music...
Press the "click" button and then set the tempo you want, press the "click" button again this will stop the metronimoe but is also sets the tempo in memory. The next time you press the "click" button it will be ready to go.
Anytime you press the tempo + or - it thinks you are trying to use the "Tap Tempo Function".
Jun 07, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
I need to install a kenwood kdc 138 in a94 ford tempo and need to know what to hook in what were
1994 Ford Tempo Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red or Black Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange download the manual for the radio and see what on the radio goes to the wires here
Dec 23, 2010 | Car Audio & Video
I have hooked this up to a working reciever that
Fill in the blanks about the working receiver.
You mention another subwoofer, which suggests your receiver manages the bass and possibly sends most or all of it to the sub.
If it's NOT sending the bass to the speaker terminals you use to drive the AM5 that would explain it's virtually silent bass module.
If those speaker terminals on your receiver can be set to LARGE, do it. Otherwise they assume the speakers are incapable of handling bass.
Apr 02, 2010 | Bose Acoustimass 5 III System
I just moved my 12" kenwoods to a new car. i'm running a 760watt amp with 6 guage wire. last week they sounded crystal clear, no rattle or anything. but this week they have a constant loud rumble,...
It sounds like you have a feedback problem between your amp and your speakers this is usually caused by a bad or weak ground between the amp and chassis ground and speakers and chassis groung, also make sure that the correct post on the speakers is the one attached to ground as this makes a big differance especially with high power systems. Hope This Helps Don
Dec 02, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Wierd problem with my subwoofers please help
It sounds like your RCAs are pickin up noise somewhere, are your rca cables next to your amp power wire? this could be the problem. Just recheck your signal wires and make sure they aren't close to any significant power cables. Also does the noise only come from your subs or your car speakers to? If it comes from all your speakers you may have a headunit problem... hope this helps
Sep 30, 2009 | Orion 12DVC Car Speaker
My L7 won't hit.
unfortunately chances are it is a bad sub. but I would hook it up to someone elses amp and then see if it works. Use same power or less for test. If it dont work then I hope you have a warrenty.
Jan 02, 2009 | Kicker Solo-Baric L7 04S12L74 Car...
Not even static?!
if the flex wires are atached from the cone then the coil is disconnected.hit me up if you need more info.
Aug 09, 2007 | Dual XINBP-210 Car Subwoofer
Car Audio & Video Logo
51 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
