Question about Intel D845GVSR Motherboard
Will not boot
Changed power supply, it is good.pc will not boot
  • 1 more comment
  • flwalks Nov 22, 2007
    Same problem. Will not boot, nothing no fans, hard drives, cd roms, on nothing. Changed power supply with no change. Read something that when the cheap power supply fails it blows the board. No other info on this found.
  • Anonymous Nov 20, 2008
    Np power or anything...
  • inlandpc909 Nov 27, 2008
    green led next to processor lights up but no response from power supply when power button press, all internal components removed bios reset using good power supply and new power switch
  • 118 Answers
Do u get a display post some info
Posted on Nov 21, 2007
  • Mohammed  Rahman
    Mohammed Rahman Nov 21, 2007
    Check your hard drives and boot priority in BIOS
    any beep codes pls post it here
  • Mohammed  Rahman
    Mohammed Rahman Dec 05, 2007
    It is a processor or mother board problem try to swap the processor and check if not swap the motherboard
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
Posted on Mar 13, 2009
2 Suggested Answers
  • 1865 Answers
SOURCE: PC won't boot up.
Try removing and reseating your RAM modules, and if you have more than 1, try using one of them
Posted on Sep 23, 2009
When i power on the PC no beep, no image, led inside PC lights ON OFF green light Please help me (my PC is HP- P4SD motherboard)
when PC cannot boot there is probably failure on installation RAM, VGA (external), or Power Supply. in your case (no beep) maybe it is your power supply don't have enough power to boot or its already damaged. try to another power supply with higher voltage (watt), or change with the new ones. hope this useful, regard riyan.
Mar 30, 2011 | Intel P4 System Configurator (P4SDRAM1) PC...
I just got an hp mini from japan so i was trying to reinstall new OS after turning it on so as to go change the boot order and restarting it the screen does not come again and i waited for a very long time...
i think you still have select your booting device is CD drive , change your booting drive option to Hard disk , if you can remove cmos battery once and place it , so that old data will be erased on PC memory and proced to your new OS.
Dec 31, 2010 | HP Mini 1000 Netbook
Power button lights up but desktop will not boot. Appear to bad power supply
Change out power supply with a computer that has worked in the past and has a similar power, supply. Check power supply for 5volts,12volts we are black box specialist noone dors this any more change out power suppy and see if it works
Nov 24, 2010 | Gateway GT5404 PC Desktop
PC won't boot up.
recheck all connections, make sure the switch on the back of the power supply (if it has one) is set to the on position. there is a chance the motherboard has failed. with the power off examine the capacitors on the motherboard, especially the ones near the cpu. if they feel rounded on the top they have failed. unless you are good at soldering... consider buying a new motherboard.
Sep 23, 2009 | Intel D865GBF Motherboard
No boot up/power-changed power supply. There is light on mother board. Power switch is good. T2862 E machine ????
remove all external devices and remove all PCI cards and if there is a modem remove it and then try
Jul 03, 2009 | E-Machines eMachines Desktop PC
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Changed power supply now it does not read monitor mouse or keyboa
Try re-seating all of the cards and memory in your PC. Unseated cards are usually the #1 cause of PCs not booting.
Mar 10, 2009 | Compaq Presario 5000 PC Desktop
Intel d815/eea2 powers up but does not boot
hi im josh in cebu phils. if it turns on but not boot. the problem is no set boot sector is selected. friend try to enter bios set up and then go to boot menu. then select hard drive to boot first.then save the changes then restart the pc. if nothing improves open your pc check the ide or sata cable if it is cut not losen.try to tighten firmly first then turn on your pc. if it doesnt work the same try to change the ide/sata cable and dont forget to give power supply on your hard disk.ok. good luck
Feb 20, 2009 | Intel Desktop Board D815EEA2 Universal...
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
You'll need this link to download the bios file;*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Jan 14, 2009 | Computers & Internet
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Intel D845GVSR Motherboard Logo
142 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
