Question about GE WJSR1070A Top Load Washer
I have a wjsr4160d5ww top load 3.2 ge washer. the
I have a wjsr4160d5ww top load 3.2 ge washer. the timer is running and won't stop. water will not come in but it tries to pump it out. The timer just clicks and grinds away. A new timer cost 137.00 and a new washer 360.
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Posted on Sep 08, 2009
heatman101
  • 43501 Answers
SOURCE: ge washer top load wlse4000goww not washing/spinning only pumps
Your type of washer usually has a belt theat runs the agitator and spins the tub. The pump is hooked by a direct coupling. If you are still pumping that tells me the motor works but the belt is probably broken or worn so badly that it no longer drives.
Have the belt replaced or do a search for "appliance parts" and then enter your model number. You will get a parts menu to order a new belt from for your unit.
Belt replacement for some of these units can be a major chore... then again some are relatively easy, but consider yourself warned if it is a real project....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 05, 2009
  • 3640 Answers
SOURCE: GE older top loading washer WWA8350BALAD pump runs but water does not fill
usually when water is turned off for a repair, rust and other things can clog it. the best thing to do is clean out the pump, and see if its dirty.
Posted on Apr 20, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE WBVH6240 front load washer
Hello, Welcome to FixYa.
The first thing I'd suggest is removing the filter in the pump you spoke of and insuring the pump is clear...there may be alot of water though so hopefully you're close to a drain or have some buckets/towels handy.
If that fails to resolve the problem it could be a plugged or faulty pressure switch. Have you run a system diagnostic yet ?
Here's how and the subsequent code meanings...in the event you don't know...
Let me know if any of this helps or perhaps you cannot read it, It is all included in the service manual I can send via email if you could use it.
Good luck.
Regards,
Macmarkus :)
Posted on May 06, 2011
GE washer wont stop filling with water
If your timer dial doesn't advance and it just keeps filling sounds like a bad timer.
Dec 14, 2013 | GE WDSR2080D Top Load Washer
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Water never stop running but the machine never started and started droping water on the floor
the timer has went bad in washer its not telling to wash or shot off or so on.
Feb 13, 2011 | GE WBSR3140DW Top Load Washer
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | GE WDSR2080D Top Load Washer
Washer will fill but it does not stop
Your water level switch is stuck.
Probably due to soap scum in the air dome line.
Remove the control console screws to access the water level switch.
Remove the small plastic hose from the water level switch and blow through it to dislodge the blockage.
If it is difficult to blow through,remove the front panel and take the hose off at the air dome on the side of the tub.
Push a small wire into the air dome to clear the clog.
Replace the hose on both ends.
Set the timer for SPIN and run a spin cycle.
Then retry the water level fill.
If it does not fill correctly,replace the water level switch.
Jun 25, 2010 | GE WBSR3140DW Top Load Washer
I have a WJSR4160D5WW top loading washing machine that is over flowing. I think it is the preasure switch, but cant find a diagram of the washing machine to figure out if it would be to hard to do myself....
The pressure switch is located up there buy the timer. Just take the that part off and there should be about four to six screws and it should get there.
Nov 19, 2009 | GE WJSR1070A Top Load Washer
Sep 08, 2009 | GE Washing Machines
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
GE WJSR1070A Top Load Washer Logo
359 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
