Question about Nikon D40x Digital Camera
Flashing red square area in viewfinder.
I have a Nikon D40 with the original lense, a AF-S NIKKOR 18-55.
I also have a AF-S NIKKOR 55-200 lense.
The 200 lense works fine, and auto focus works with the current camera settings.
However, when I put the 18-55 back on, the focus area in the viewfinder flashes red instead of black when it is finding the focus area.
Did I adjust a setting by mistake???
  • lmustille Nov 20, 2007
    now my 200 lense does the same thing!
    must be a setting???? what is it??
    Any help is appreciated!!!!!
  • 150 Answers
No, I don't think so, there could be differences between the Auto and the P setting. But the red flashing is where your camera is currently focusing on. It's possible that the black was indicating the focus box, but it was not latched on to something with complete focus, which then is indicated by the red flashing. Check this link to read up further on this. I may not have pinpointed it exactly, because I have a D70s, but that's what I found so far. You'll maybe have to reset everything and see if it's still there, otherwise, it's a setting. =)
Posted on Nov 23, 2007
I have a Nikon D40...will the 55-200mm f/4.5-5.6 G AF-S lens fit my camera??
Yes. Not only that, but it will autofocus and meter. In short, everything will work (assuming the lens isn't broken).
Apr 19, 2010 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Small piece of clear white plastic lodged in the viewfinder
Check the mirror in the camera for any debris, or the lens. Sometimes a quick brush off works wonders!
Jun 11, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Best Auto focus Tele For Nikon D40
hi ! iam too a D40 holder,u can opt for AF-s versions or HSM sigma,both of them autofocus on d40,can go for 18-200 AFs VR or if u need still longer end go for 70-300 but it is costly than the sigms 70-300APO DG HSM MACRO..,its a much better reviewed lens and dont forget the cost..anyway do some research before considering..good luck
Mar 14, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Can Nikon D60 work with 18-200mm f/3.5-5.6G Zoom Nikkor
Yes, it will work just fine. I have this lens and my father has basically the same camera (D40) and it works just fine with this lens.
Feb 22, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikkor lense
You need AF-S or AF-I Lenses. These have the autofocus motor built in to the lense. The D40 and D40x does not have an autofocus motor in the camera body itself, while the D80, D300, D3 Etc to have the motor in the camera. You can use most old lenses on your D40x, but you will have to focus them manually.
See Ken Rockwells page for a lot of D40 / D40x info
Jun 03, 2008 | Nikon D40x Digital Camera
Lens wont allow me to take picture
That may be the "insert memory card" error.
May 13, 2008 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Nikon D40x Digital Camera Logo
230 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
