Question about E-Machines eMachines Desktop PC
Output A:\GHOSTERR.TXT? I am on disc 2 and at 75% when I get this question and if I say no then the recovery stops and says its finished but locks up on the A drive when booting. If I say yes I get the message "cannot open GHOSTERR.TXT - insert diskette". What do I do, symantec no longer handles support calls for the e-machines.
    Problem Solver:
  • 5 Answers
Try cleaning the cd, if no luck; use a friends pc and burn a new copy of the restore cd.
Posted on Jul 26, 2009
I got the same problem my solution is -to burn image again with new cd and use nero program with lowest speed.
Posted on Aug 28, 2009
  • 241 Answers
Try going to a friends computer and getting on the internet and going to google.com. In the search box put "ghosterr.txt" and search. There are numerous finds about this problem.
Posted on Jul 23, 2009
Reformatted w2060, assuming that the recovery disk would work. now i keep getting ghosterr.txt error at barely 3% recovery. cleaned cd. no use. "chatted" with bangalor...i mean...
I'm assuming that you formatted your drive because you were experiencing problems. I would suspect that you have some bad sectors on your hard drive. Those bad sectors may have been causing your initial problems as well.
Without replacing the drive, I would recommend downloading a copy of UltimateBootCD (link below). Burn and boot off of that CD and run Darik's Boot and Nuke under HDD. This will write zero's onto all sectors of your drive.
If you can identify the manufacturer of your drive, you can boot off the UBCD and run the manufacturer's diagnostic tools. These will typically include a surface scan which will check for bad sectors and prevent the drive from using them.
If you have a significant number of bad sectors, there may be an ongoing problem. After a while, the drive will become completely useless. If that is the case, you'll need to replace the drive.
Ultimate Boot CD site: http://www.ultimatebootcd.com/
Feb 24, 2011 | E-Machines W2060 (RB-W2060) PC Desktop
My asus eep pc 701 sd its says reboot and select proper boot device or insert boot media in selected boot device and press a key ive attached a external drive and booted from the disc it stops after 10...
It looks like either the laptop HDD has failed or has become dislodged. Remove the HDD coverplate and ensure the HDD is correctly seated and secure it.
As to the ghosterr.txt problem the biggest cause is a dirty/scratched disc.
Jan 14, 2011 | Computers & Internet
I need to create recovery disks for my HP Pro Book 4310s in case I need to restore it back to factory settings in the future. I just got this computer and was I told I should get this done. I am running...
Hi.
Please follow the steps to create the recovery discs using the HP Recovery Manager.
Click Start>AllPrograms>Recovery Manager.
Select Recovery Manager. This will open Recovery Manager.
Click Advanced Options. If you are using a laptopand operating on battery power alone you must connect to anAC power outlet before you can go to the next step.
Select Recovery disc creation. Click Next. The Recovery Manager will begin creating the necessaryfiles. This may take a while, so be patient until the bar has reached 100%.
Read the table of requirements thatappears. Depending on the type of discs you use, more or less may beneeded; if you use ordinary CDs, Recovery Manager will require more compared tofewer discs if DVDs are used.
Insert your first blank disc, havingmade sure it is fully labeled, such as "Recovery Disc 01" or"Recovery Disc 1 of 2". The optical drive of your computerwill have automatically opened. If not, open manually. Close the optical driveand click Next.
Understand and confirm you want to gothrough with the operation using the type of disc you have inserted by clickingNext.
Wait while Recovery Manager now createsthe first disc. This may take 20-40 minutes as it collects the files,writes the files and verifies the files to disc.
Remove the disc and insert the nextafter the first has been finished after clicking Next. Continue the creation of discs according to thenecessary requirements, up until the last has finished creating files.
Click Next after removing the disc and then Finish to complete the session. Congratulations! You havejust made yourself a set of recovery discs.
Use the recovery discs to recover yourcomputer in case of system instability or failure.
Thanks!!!!!
Dec 29, 2010 | Computers & Internet
Am trying to open my emachine laptop and it will show operating system not found. i want to use the restore cd but it can't continue. it is showing cannot open ghosterr.txt. what should i do?
Its a RAM issue. you should open your laptop and reinsert your RAM. If you cant do so then go to nearest service center and ask him to reinsert RAM. okay
Aug 19, 2010 | Computers & Internet
Laptop will not boot when turned on
Go into bios and make sure that your cd player is set up as the first boot up device. Then insert the disk, reboot and follow the prompts to install the OS. When thru get the drivers you need and you are good to go!
Sep 11, 2017 | Averatec 3150H Notebook
Output a ghosterr.txt message when I use the Restore CD's
You can change the default abort file (ghosterror.txt) location and name by specifying the switch -afile=filename where filename contains the path and name of the error file you wish to create.
Example: ghost -afile=c:\errorfile.txt
Please try this switch and post your error file if you are successful.
Nov 12, 2009 | E-Machines eMachines Desktop PC
Recovery disk 1 emachines windows xp
i took out the speakers i had from the output socket abd then it worked
Aug 30, 2008 | E-Machines eMachines Desktop PC
Norton ghost 2002
Under DOS? Windows? Or Ghost app?
Jan 06, 2008 | IBM ThinkPad 600X Notebook
I was trying to do a full system recovery
I HAVE A E-MACHINE. If you have any C/files they will be lost ... But go ahead and un-plug power for at least one-minute. reapply power and insert the 1st Restore disc and continue through all your discs. If it asks for administrator it will cue you to type in a NAME for the user and a password. Make sure you save the password somewhere. It sounds like one of the discs did not properly load and caused a failure.
Its worth a try. Lucky you have a e-machine. Other computers like Dell dont give you the restore discs and you have to pay for Windows XP or Vista. Or take it back where you bought it.
Oct 11, 2007 | E-Machines eMachines Desktop PC
Continuing formatting trouble
Hi Shawn, It sounds as though your recovery disk has Norton Ghost incorporated into it, thus the call for the Ghosterr.txt file. Most recovery disks are just modified Windows installation CDs and if you boot to them they will immediately go into the Windows recovery which is what Sandrew was trying to walk you thorough. Having said that I?ve found a few other references to this type of issue and has usually been a result of CD read errors. - Try cleaning the recovery disk, if there are severe or numerous on it or if it is dirty that could be your problem. - If that doesn?t do it try cleaning your CD drive with a good commercial cleaner. - If that fails another option is trying a conventional Windows installation CD. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Averatec SL3150H-01 Notebook
E-Machines eMachines Desktop PC Logo
1,223 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
