Roper washing machine type 107 won't fill up but 3
Roper washing machine type 107 rax 4232 rqo won't fill up but 3 inches
  • 221 Answers
Check the pressure switch, and the water level sensor
Update ma about your progress
Posted on Jul 25, 2009
Roper Washer fills only 6 inches on small, only half on super. This is the wash cycle.
I had the same problem with my Whirlpool and I had to replace the fill level control. It was easy and inexpensive as I found it on eBay.
Sep 20, 2015 | Roper Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Roper RAX 5133AWP WASHER WONT DRAIN
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 12, 2009 | Roper RAS8445KQ Top Load Washer
Roper topfill washer fills, washes but will not spin. Type: 107 Max.: RAX7245KQO Serial: CL 3617156
Did you check the lid switch? continuity would tell you, simply remove the two screws for the top (timer consol) phillips screws . then you will see a white plug on the cabinet disconnect it then shut the lid or stick a pen/ or something to activate lid switch stick your ohm meter in the 2 end holes, make sure you have no electricity and check with continuity.here is the lid switch for your model
Apr 24, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a roper washing machine Model# RAX 4232RQ4 that leaks water near the front, checked hoses and drain all seemed fine, how do I disassemble cabinet to look at?
it may be a bad pump they are usually toward the fron of the washer. Just tip it back far enough so you can look under it while laying on your back make sure it doesn't come back down on you. When a pump goes bad it will leak where it connects to the motor shat. simple and easy to change Good Luck.
Mar 23, 2009 | Roper RAS8445KQ Top Load Washer
UNBALANCED WASHER
Does it happen all the time, with no connection to laundry quantity? In case of a positive answer, it sound like a shock absorber issue. Could be that it's moved from its place or become malfunction and should be replaced. Good luck
Aug 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper Washing Machine works after I jolt it
See link: http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
Jul 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
377 people viewed this question
Top Washing Machines Experts
