SOURCE: 1997 Chevy Cavalier intermittent starting
I had the exact same problem on my 1998 Chevrolet 1500 c/k pickup. I also tried a new starter motor and solenoid assembly, but to no avail.
After weeks of searching for the problem, I found that corrosion had built up between the car battery terminals and the power cables extended from the car battery to the starter motor. I'm not sure if this is your problem, but it's worth a try. Also, check all other electrical connections, because these types of intermittent problems are often electrical.
SOURCE: A/C and Heat Driver Side Intermittent Problem
You will need to replace your driver side temp actuator. It is most likely sticking or over travelling. It is located under the dash directly below the a/c control head. It is bolted to the a/c box upside down with two small bolts. Let me know if i can help more.
SOURCE: 2001 Chevy Tahoe radio problem
Your Display will Eventually Stop alltogether. Happened on my 2000 Blazer and had to replace with Aftermarket Stereo. Dealer wanted WAY too much for new unit.
SOURCE: im having trouble pumping gas into my 2005 chevy
Try checking the vent tube. if you look under the truck it will go from the gas tank filler tube to the top of the gas tank.
SOURCE: 2007 chevy avalanche electrical issues
You need to remove the carpet on the passengers side and check the wireing harness,take off the tape and visually inspect it.You are likely to find broken splices ,bare wires or wires shorted to each other or to ground.
