Where is the lid switch at on a Roper washer. Serial number RTW4340SQ0?
  • 5,911 Answers
The lid switch on your washer is located under the washer casing in the back by the left washer lid hinge. It is activated by either a rod from the left hinge, or an activator which closes when the lid pushes on it. If you go to searsparstdirect.com, you can view an image of what I'm talking about. Type in your model number and look under the "Top and Cabinet" parts section for item 11 (part number 8318084). If you click on the enlarged image of item 11, you can get a better close up view.
NOTE: You can also view all the same info at appliancepartspros.com. The price may be a little cheaper.
If you need to remove the washer casing to access the switch, follow these steps:
1. Unplug washing machineWhere is the lid switch at on a Roper washer. - 2.gif.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To put the case back on, follow these steps:
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 23, 2009
How much will a lid switch cost for a roper washer serial # sm828087
If it were me, I'd first go to "Sears parts" and find the model number and part number of the part you need on their free diagram.
Then, I'd got to e-bay and type in that part number and see what that part would cost. I have often done this myself.
Be blessed.
Apr 21, 2013 | Roper Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Does the roper washing machine top loader model# RTW4340SQ0 have a place to put in the liquid softener?
I have the same question but have not find a manual or any other reference that tells me whether this model has a softener dispenser or not. However, I just found this info: http://www.repairclinic.com/PartDetail/Fabric-Softener-Dispenser/8575076A/1195942 which is linked to roper washing machine RTW4340SQ0 parts list. It looks as if the washer doesn't come with the softener dispenser as original equipment but that you can buy this dispenser at repair clinic and just assemble it to the agitator as shown in the video that you will find in the link
Jan 13, 2013 | Roper RTW4300SQ Top Load Washer
How do i put my roper RTW4340SQ0 tub back on its track?
could you please describe the problem you are having a little better?
There is no "track" the tub goes on.
Nov 28, 2012 | Roper RTW4300SQ Top Load Washer
I have a Roper RTW4340SQ0 and my washer filled straight to the top and would not cut off it flooded my house what could this be?
There is a pocket on the side of the drum which is designed to trap air, this air pressure
in turn operates a switch to shut off the fill valve. It has a clear hose running to it and
sometimes lint will get caught in the line at the drum connection. You can open the
top control panel (usually the two screws at the base of the panel) and the panel
will hinge up. Make sure you unplug machine before servicing. The switch will be
obvious as it has one clear line and two connections on it, It is round. Remove the line
and blow into it to be sure that any lint clogging this line is cleared. Reattach and test if
you cleared a clog. If the line is clear then I would replace the switch. model is under the lid
One other possibility is that the fill valve stuck open, but I have never
seen this happen in 10 years servicing top loaders and stacks. Hope this helps. :)
Mar 31, 2011 | Roper RTW4300SQ Top Load Washer
Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Jul 24, 2009 | Washing Machines
Roper topfill washer fills, washes but will not spin. Type: 107 Max.: RAX7245KQO Serial: CL 3617156
Did you check the lid switch? continuity would tell you, simply remove the two screws for the top (timer consol) phillips screws . then you will see a white plug on the cabinet disconnect it then shut the lid or stick a pen/ or something to activate lid switch stick your ohm meter in the 2 end holes, make sure you have no electricity and check with continuity.here is the lid switch for your model
Apr 24, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper washing machine leaking water
Might be a cracked water valve or dispenser. To get to it you must remove the skin. Click HERE for info on accessing these fine machines.
Feb 22, 2009 | Roper RTW4100SQ Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
445 people viewed this question
Top Washing Machines Experts
