Question about KDS Radius RAD-9p 19" Flat Panel LCD Monitor
RAD-9p shuts off for no reason
My RAD-9p won't stay on. I see others with same problem but don't see a solution, is there one?
  • 7 more comments
  • 1_bad_kitty Jul 23, 2009
    Closely checked all capacitors and all are good. Any other suggestions?
    sent photos to email at web site noted in message
    Did you get photos?
    how do I determine which it would be?
    My power cord has the round 4 pin plug to monitor and I believe it has a yellow power light.
    Power light does not pulse or blink at all. I have sent photos of cord.
    Did you get photos of power cord?
  • 1_bad_kitty Jul 26, 2009
    have you given up on my problem?
  • 1_bad_kitty Jul 29, 2009
    HELLO BUDDY - HAVE YOU GIVEN UP ON MY MONITOR PROBLEM
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 23, 2009
  • 4 more comments
  • Buddy Mcsparrin Jul 23, 2009
    Hello again,
    Can you take a few pictures of boards in your monitor and I will see if we can get it going for you.
    Buddy
    Yes, Got the photos and I am working on the problem. I do need to check, there are 2 versions of your monitor, one has an external power supply and one has it built in. Which version do you have?
    Does the monitor have a power adapter or does a big power cord plug right into the monitor? If you have the model with the power adapter it should have a green power light.
    Can you check the adapter, my specs show a standard round plug with only center and outside connections not 4 pin. Also does the light on the power adapter blink or pulse at all?
  • Buddy Mcsparrin Jul 24, 2009
    Yes, We are looking into the problem.
    Buddy
  • Buddy Mcsparrin Jul 29, 2009
    NO, Still doing research on the model.
    Buddy
My 2006 toyota sienna DVD player won't shut off
Engine room Junction Box - on left side of Engine Compartment (Drivers side in USA) - Fuse RAD 1 (20A), Fuse RAD 3 (30A) - there is another fuse that goes to your ECU, it works with the radio, but you won't need to pull it. In case you do - it is Fuse ECU-B (10A)
Oct 14, 2013 | Cars & Trucks
Fuel safety switch location or other reasons it won't start after crash.
Generally speaking, only Ford products have a safety switch or inertia switch for the fuel system. This includes some Mazda models.
I would start with the basics and check for power to the coil and the fuel pump relay.
Jul 06, 2013 | 2000 Hyundai Elantra
MY CYBER HOME TV WONT STAY ON
The reason for this type of faults are very difficult to detect. Contact any service technician.
Jun 06, 2013 | Cyberhome CH-LCTV 150 15 in. LCD...
I have a 1996 acura rl and my problem is my remote entry won't work and my cluster light won't shut off and the check engine light came on all at once don't have a clue as to why
remote entry wont work because either remote battery is dead or remote broken.cluster light will stay on if head light stay on could have faulty headlight relay or headlight control unit faulty let dealership check it out.
Sep 09, 2012 | Cars & Trucks
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
Phone won't shut off. Display stays lit all the
The software got stuck whil shutting down. Try resetting it to factory defaults after saving your phone book and other valuable info on there.
Jun 26, 2011 | Samsung Cell Phones
I have a KDS 5ms model 900W this was never used as my sister gave it to me since she was unable to get it to work. but like the others it won't stay on for more then 7 secs and you need to push the power...
These have problems with burning up transistors on the inverter side of the powerboard.
Sometimes they are fixable, sometimes not. It depends on which board is in it (they used 2 different styles)
I have done a few of these.
If you can open it up and send me a picture of the board to bammbamm@ptd.net, I may be able to tell you more.
Fran
Aug 13, 2009 | KDS Radius RAD-9p 19" Flat Panel LCD...
RAD 9p shutting off Have checked all capacitors
Hi
The capacitors need to checked with an ESR meter. Althought capacitors sometimes bulge when they go bad this is not always true. Capacitors change value internally very easily when the conditions are right. High heat.
You can send this to my company for repair or if you need more help go ahead and email me.
Thanks
Jul 23, 2009 | Computers & Internet
KDS Rad-9p wont stay on
my monitor will not work it will come on when the pc is cut on but it will not display
Aug 24, 2008 | KDS Radius RAD-9p 19" Flat Panel LCD...
KDS Radius RAD-9p 19" Flat Panel LCD Monitor Logo
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
