Irons Logo
Joan Parry Posted on Feb 21, 2017
I have a Bosch steam iron sesixx B25L, I have carried out the de-scale procedure but still no steam coming through the Iron, any Ideas?
5 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 24, 2008
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Anonymous
  • Posted on Dec 20, 2009
SOURCE: I have a Bosch steam generator iron B25L
yes my bosch did the same but then it started working again only to pour vast amounts of water all over the clothes
Anonymous
  • 244 Answers
  • Posted on Jun 02, 2011
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Aug 01, 2012
SOURCE: Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Anonymous
  • 7 Answers
  • Posted on Apr 08, 2013
SOURCE: i have a bosch B25l steam generator iron, it will not steam
Try a quarter teaspoon salt added to the water. Switch on and let it steam through. Do this Just once.
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
3helpful
I have a bosch B25l steam generator iron, it will not steam
Apr 08, 2013 • Irons
2helpful
Bosch Sensixx B25L
God bless you
Jul 31, 2012 • Bosch Irons
4helpful
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 • Irons
12helpful
3answers
74helpful
2answers
Bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Feb 22, 2010 • Bosch Irons
Top Bosch Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bosch Iron Expert? Answer questions, earn points and help others
