Question about Intel D845GVSR Motherboard
Will not start
Changed power supply, green light on mobo. no boot
  • gldtr Mar 24, 2009
    I have a T2862 Emachines, same isue, Replaced UPS with a working one, still unable to turn on Pc, I see a green ligth on the mb but no activity on drives or Power switch fan not working. I replaced all drives also, still unable to turn on Pc.
Actully the problem is there for the last 3 years, but still i do not know the cause. " when i start the system sometimes it wont start, ie. the keyboard lights get on, HDD is on, CPU fan working, but no output on Monitor(it remains off). Additionaly sometimes when i am working on system it gets off, and does not restart and goes into the above mentioned condition. then i switch off the system by pressing the power botton for 5 seconds. laterwhen i turn it on, then it may turn on or it mays not and go into above mentioned condition. And sometimes the system runs for hours even all night and there is no promblem of this type." Can someone tell me what is the problem with my system?
Posted on May 30, 2009
  • 661 Answers
I'm guessing that your computer was not working before the PSU change....
To find out what your problem is you have to Eliminate as many possible sources as you can, hence remove all your PCI cards and drives, (not your graphics card though, memory or CPU)
Check boot again... if it still fails to boot then it's either the CPU the MEM or the Motherboard....
if it does boot then plug in some of your cards, (but not all) and check again.... if system fails again, systematically check each card that you re-inserted.. this should help you find the culprit...
Posted on Dec 05, 2007
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
I have a gateway gt5662 given to me from a friend who was going to trash it. Got it home and plugged it up and the started on its own. No lights are on the MoBo. and the and some of the fans work and...
If it was the CPU it should still give you some sort of beep or diagnostic code.
On the back of the power supply there is some times a little light, when you power up if there is an issue with the power supply it will blink or change colors. Some times the power supply testers will light up green but there still can be issues and you need to use a voltage meter to do a more advanced test.
Have you tried removing any extra hardware and then trying the boot?
Apr 13, 2010 | Gateway GT5662 Desktop PC
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Asus p4p800s-x won't boot and no display on the monitor..
get a better power supply, as i understand it, youre computer is getting too little power from it. pick a power supply with more volt
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Troubleshooting no screen output, please help
sounds like your system is not booting, that may be, obiusly you just have power but that's it...no boot routine. hope somebody else could help on "how to make sure your system can boot again, then the rest.
Dec 23, 2008 | ASUS A8N-SLI Motherboard
I have a media center cpm 1180n desktop, the green light on back of PS is blinking and when I disconnect the mobo is steady green however when I connect the mobo back to my MB and press the start bottom...
yes it sounds like the power supply is shot, you can get a replacement at any computer shop for around $40. i would put in a 400w or 450w that way if you add another hard drive or opitcal drive it wont be a strain on the new power supply
Nov 30, 2008 | Computers & Internet
Gren power light come but won't boot up
Well could be a few things... But i would start with the PSU, Ram, Then the mobo
Nov 17, 2008 | Computers & Internet
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Dell dimension 5100 won't power on
might be a problem with the power button...try exchanging the power adapter and the reset adapter in your motherboard...this would become:
RESET BUTTON: as power button.
view your manual on where to find this adapters in your board.
Nov 19, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Intel D845GVSR Motherboard Logo
197 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
