Water leaking all over
Our portable air conditioner leaks all over the floor. How do I stop this?
    Scholar:
  • 86 Answers
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Posted on Jul 25, 2009
madman775
  • 5 Answers
SOURCE: leaking unit
check to ensure that the drain hose is not touching the side if the water storage bin. if still no luck then watch unit when running to assess the leak point............maybe a hairline crack in water container
Posted on Nov 02, 2009
  • 166 Answers
SOURCE: sharp air conditioner portable leak in bottom
You mean it's leaking around the AC's unit base? If so, here's a handy diagnostic article that specifically addresses this problem of yours, explaining the probable causes and solutions, a solution that may very well have to do with the condensation pump's malfunction or just debris blockage, among other things: http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm This article should set you on your way! Good luck! Brad
Posted on Jun 13, 2009
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
22yooper
  • 828 Answers
SOURCE: rv air conditioner leaking
In each of these cases I would check for proper connection of the return air vent to the A/C from below. Static pressure from insufficient return air could cause negative pressure to hold back on condensate drainage. when the unit is shut off the pressure becomes equal allowing water to drain. Also check air filter and clean if found necessary.
Posted on Jul 18, 2008
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Tip
How to stop portable air conditioner leaking water
I heard that some portable air conditioners can leak water from the unit after being operated for about an hour or so if they are not on a level floor. <br /> I solved this with my DeLonghi air con after discovering the floor my unit was on had about 1 - 2 mm difference from one side to the other. By buying a small builder's liquid level (like you use to keep a line of bricks aligned) I used a small piece of wood (ruler thickness) under one side of the air con and no more leaks! Hope this helps someone. Kez, Perth WA
on Jan 30, 2011 | Heating & Cooling
Water leaking from beneath unit. Some water enter buckets some leaking onto floor. Can't use the unit it leaks so much.
Look for the drain tube which sends the water to the buckets. It may be disconnected or misaligned allowing the water to go the wrong way. The tube can also be stopped up. Blow through it to clear.
Jul 22, 2011 | Danby Portable Air Conditioner
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
Leaking unit
Oct 30, 2009 | Heating & Cooling
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Aug 23, 2009 | Frigidaire FAP094P1Z Portable Air...
Jul 26, 2009 | Pelonis KCD-25YI Air Conditioner
Heating & Cooling Logo
1,299 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
