This usually means you either might have a faulty charger cable. Or it is connected to the wi-fi. I am guessing it is off. Try letting the ds run completely out of battery to the point where you cannot even turn it on. Then plug the cable into the ds first. Then plug the charger into a different outlet. Hopefully this solves your problem. Good luck :)
Hi, it might be the fuse. Does the DS turn fail to turn on? Does the charge light just flash briefly when you plug in charger? If so it will be the fuse. If the console it out of warranty, maybe you or someone you know can fix it. Check out the following youtube videos Good Luck
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from NintendosOnline Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
electric shock from ds
