SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
SOURCE: LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
SOURCE: Frigidaire Front Load Washer Problem
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
SOURCE: LG WF-17014PP will not rinse or spin
I have the some problem with LG type WFC 5856 TC. The motor can't turn for water
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
