Operation panel (touch screen) Ricoh 3224c
The touch screen on my copier is not working. I am having a hard time locating the touch screen online and I am looking for the part number for the touch screen of a Ricoh 3224c
    New Friend:
  • 22 Answers
H310-6173
Posted on Jul 23, 2009
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
How to reset SC544 for Ricoh MPC 3000 when the keyboard is faulty
Maybe TOUCH panel doesn't work.
Try to calibrate it:
Yellow -->1-->9-->9-->3--> Press Stop(red one) 5 times.
1 - Touch screen adjustment!!! Follow instructions on the screen.
After calibrating exit and try again to enter service mode.
Good luck
Prepare to by new TOUCH Panel
Pifonski
Sep 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh aficio SP4100NL error sc 546
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
    • 1 Press the "Clear Modes" button. This button will be on the main panel.
    • 2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
    • 3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
    • 4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
    • 5 Turn off the main power. The main power button will be located on the side or front of the copier.
    • 6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
Jul 20, 2014 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Ricoh aficio 3224c error sc570
Insufficient oil (the oil tank in the rear of
the machine)
Feb 25, 2011 | Ricoh Aficio 450 Copier
Pls we need your help with ricoh affico printer 3224C the screen of it write this message : used toner bottle setting error used toner bottle -2 is not set properly. open the part as shown and set the...
look my friend used toner means that this toner is disposal or exhausted ok ensure that empty exhausted toner not mean fresh toner are yo ander stand
Jan 12, 2011 | Ricoh Aficio 1035 Copier
I have a ricoh 1045 , and I can not read the display looking down, but I can see everything in an angle. Can you help?
See the display panel contrast button position(in the left side to user tools button.).If not work perform the touch screen adjustment:Press the total stop key(yellow)-1-9-9-3-clear/stop key(red button) x5 timeand press enter key(double croice).The graphic sensing adjustment screen will appear.Touch the upper left corner then the lower right corner of the panel using a pointed tool.Touch a few spots on the LCD and confirm that the marker appear on the screen at exacrly the same location as the pointed tip.Touch enter on the screen adjustment.Turn off the machine and back on to store the settings.
Sep 26, 2009 | Ricoh Aficio 1035 Copier
Access ip address inofmation page on aficio 3224c
Type the IP address of your machine into your web browser. Login to Administrator Mode as follows:
Username: admin (or possibly "administrator")
Password: (leave blank)
Mar 11, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
1,215 people viewed this question
jasbo
jasbo
