Televison & Video Logo
H
HELENA BOOYSEN Posted on Feb 21, 2017
I would like to receive the different packages of dstv with values
Ecco LH32S Smart tv. How to install DSTV on it? It doesn't show on my App Store tv.
DSTV is not an App, it is a Paid Streaming Service. You have to contact them, pay and they arrange how you get it.
Get DStv and Watch the Latest Sport, Movies, Series and More
DStv https://www.dstv.com The best in television entertainment at your fingertips. Watch the latest sport, movies, series and reality shows and access the DStv TV guide.
DStv Now
Watch your DStv Stream online. Stream Live Sport, Catch Up on ...
Nigeria
Compare Packages - Stream with DStv - Contact Us - Get DStv - ...
Get DStv Stream
What is the DStv Stream app? The DStv Stream app is where you ...
Dstv Uganda
Compare Packages - Need help? Contact us - Get DStv - ...
Contact Us
Save our number 060 060 3788. All you have to do to get started ...
Aim 60 Inch Digital UHD. There is no sound from my dstv HDMI connection only, picture is fine, decoder tested by dstv fine, other HDMI inputs work fine, I know the HDMI cables are fine. please assist.
If you're not getting any sound from your DSTV decoder when connected to your Aim 60 Inch Digital UHD TV via HDMI, there are a few things you can try:
  1. Check your TV settings: Make sure that your TV's audio settings are set correctly. Check that the volume is turned up and that the TV speakers are not muted or turned off. Also, make sure that the TV is set to receive audio through the HDMI input.
  2. Check your DSTV settings: Make sure that your DSTV decoder is set to output audio through the HDMI connection. You can usually check this in the settings menu on the decoder.
  3. Try a different HDMI input: If you have other HDMI inputs on your TV, try connecting the DSTV decoder to a different one to see if the problem persists. This will help to narrow down whether the issue is with the HDMI input on your TV or with the DSTV decoder.
  4. Try a different HDMI cable: Even if you think your HDMI cable is fine, it's possible that there is an issue with it that is causing the sound problem. Try a different HDMI cable to see if that resolves the issue.
If none of these steps solve the issue, it's possible that there is a problem with the HDMI input on your TV. In that case, you may need to contact Aim customer support for further assistance or consider bringing the TV to a repair shop.
My Dstv receiver model 65 is not responding to dstv remote control model B4, what should I do?
If your DStv receiver is not responding to your remote control, here are a few troubleshooting steps you can try:
  1. Check the batteries: Make sure that the batteries in your remote control are fresh and properly inserted. Weak batteries can cause the remote control to stop working.
  2. Reset the remote control: You can try to reset your remote control by removing the batteries, pressing any button for 5 seconds, and then reinserting the batteries.
  3. Clean the remote control: Sometimes, dust or dirt on the remote control's buttons can interfere with its functionality. Clean the buttons with a dry cloth or a slightly damp cloth to remove any buildup.
  4. Reset the DStv receiver: Try resetting your DStv receiver by unplugging it from the power source, waiting for 30 seconds, and then plugging it back in.
  5. Re-pair the remote control: If none of the above steps work, you can try re-pairing your remote control with the DStv receiver. To do this, press and hold the "Shift" and "TV" buttons on the remote control for 5 seconds, then enter the 4-digit code that corresponds to your DStv receiver.
If none of these steps resolve the issue, you may need to replace your remote control or contact DStv customer support for further assistance.
How and where can I lodge complaints on DSTV programs and packages?
I would suggest phoning or emailing your DSTV provider. Any company that provides a public service should have clear contact info
Jan 05, 2015 • Cell Phones
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
