Question about GE Monogram ZISS480DRSS Stainless Steel
Compressor of built-in monogram burning up. Should it be?
My GE monogram was making a ticking noise and the freezer wasn't working. One repairman came out and said we need a new compressor for a charge of $25oo. A GE repairman came out and said we just need a new timer. The compressor still feels very hot as do the sides of the doors when you open them. Should the compressor always feel hot?
  • GE Master
  • 4,654 Answers
Don't know who to believe these days. When the compressor won't start and over heats the start relay,start capacitor and external overload may be the most likely reason. The door frames have heat strips that is normal. Sea Breeze
Posted on Jul 23, 2009
  • John Tripp
    John Tripp Jul 23, 2009
    If the compressor is too hot to touch you need to disconnect the power to prevent damage to the internal overload until the problem with the start components are repaired. We also should check the compressor windings once cooled down to make sure the compressor is not burned out. Not likely but need to check before spending money on parts before purchasing. Sea Breeze
  • John Tripp
    Thank You very much for the Rate! If you need any help feel free to let me know. Thanks, Again, Sea Breeze
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 488 Answers
Try to clean condenser coils with a soft brush. put flash light on one side of condenser coil and see if u see it on other side, if not at all or not much, just clean it up and u will be good to go. I have video of compressor change out on GE Monogram, check it out. I hope That will help u!
Posted on Mar 01, 2015
Bad humming noise for ge monogram ice maker zdis150wss. stopped working entirely.
pretty big job to replace compressor on this refrigerator. Thats video I made on one of my customers monogram. Hope That helps.
Apr 20, 2011 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZISS480DRSS - freezer and refrigerator both quit cooling. I had a mostly plugged condenser coil - cleaned it & still no cooling. What would be the likely component failure path to check?
replace the ptc overload relay on the compressor as this supplies power to the compressor,it may sound like the compressor is operating,but possibly only on the start windings and will be very warm to the touch,if so replace it soon so as not to burn out the compressor motor windings
May 19, 2010 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Jan 01, 2010 | GE Monogram Side by Side Refrigerator
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
I have a monogram zisb36drb that leaks in the freezer compartment
This can be fixed.  It's not a defect at all.  The drain is plugged.  I will warn you these are a pain the butt to get into so I would reccomend an experienced repairman to do the job.  You can expect to pay about $200 for this repair due to labor time.  Would appreciate a solved rating for expert advice.
Oct 18, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS480DRSS Stainless Steel Logo
796 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
