Question about Texas Instruments TI-Nspire Graphic Calculator
My calc wont turn on at all no matter what i do.
  • Texas Instru... Master
  • 7,993 Answers
Try these, courtesy of the TI Knowledge Base
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Posted on Oct 18, 2009
  • k24674 Oct 26, 2009
    If the information taken from the Texas Instruments Knowledge Base does not solve your problem, maybe you should contact them and give them a piece of your mind. Since the product is relatively new it may still contain bugs.
    Contact information follows:
    USA, CANADA, Puerto Rico, and the Virgin Islands.
    phone: 1-800-TI-CARES- (1-800-842-2737
    e-mail: ti-cares@ti.com
    Technical questions 1-972-917-8324 (not a toll-free line)
    Outside the USA, CANADA, Puerto Rico, and the Virgin Islands
    Internet www.ti.com/calc
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
Does not responce, can't turn it off
when the calc is on do you see the cursor blink if it blink and no button works check maybe one of the buttons stuck if it does not blink its an hardware problem
May 29, 2012 | Texas Instruments TI-84 Plus Silver...
My TI-89 Titanium is stuck on the main screen and no matter what button i press nothing happens. I have tried changing out all of the batteries and nothing is working.
Hi
when you turn on the Calc press the 2nd button and if the busy indicator is on its and hardware problem or if none of the keys is working
let me know if you want to fix
ecrdn@yahoo.com
Jack
Jun 26, 2011 | Texas Instruments TI-89 Calculator
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
I can't find the Calculator in Accessories, how do I find it in all programs?
Calculator is supposed to reside in Accessories, unless it has been removed or uninstalled.
To confirm it does exists (no matter which version of windows you are running).
click on START and then RUN and past the following: %windir%\system32\calc.exe and then press the ENTER key.
Calculator should start.
or you can search for calc.exe on your pc and create a shortcut on your desktop.
if it was uninstalled, you will need the source Windows CD and re-install using ADD/REMOVE programs.
Sep 28, 2010 | HP Computers & Internet
My calc wont turn on i changes batteries and back up battery, still it wont turn on.
Hi:
you calculator is on, you need to adjust the brightness , try 2nd up botton or down button this will darken the curser so you can see it than press some numbers and see if you can see them . okay
Oct 10, 2009 | Texas Instruments TI-84 Plus Calculator
Lag + Doesn't shut off... (ti84plus)
the I/O plot matters. If blowing doesn't help, insert a stick or something into it. I had the same problem, and my TI 84 plus had already been extremely unresponsive and slow before, as I fixed the latter problem by blowing really hard into the I/O plot, I did the same to fix the new problem. For many times nothing happened. Then I insert a metal stick into it and gently hit it inside. In a short while, the calc was normal again!! Now my calc even turns on when it's been put off, with its cursor frozen. I simply use my little finger to dig/scratch the plot and see the lovely cursor beating again. PS Having such a funny calc is really bad, but every time you fix it you'll feel good
May 27, 2008 | Texas Instruments TI-84 Plus Calculator
Darken screen!!!
reset your calc, press 2nd left right on simultaneously. it should work.
Apr 25, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
600 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
