Question about Kenmore 44102 Front Load Washer
Front load washer wont spin
Every thing work but no spin was told to change control board and did but same thing happens (fills agitates drains but no spin) need help thanks I have a Kenmore front load washer which I think is made by Frigidaire. It goes through the wash cycle correctly but does not do the high speed spin at the end. The was drains completely and it also does the back and forth motion at the very end of the cycle. It does this for ALL cycles (rinse and spin, normal, quick, etc.). The pump was very noisy so I replaced it hoping that would solve the problem but it didn't. I also replaced the motor control board (part 134743500) but that didn't help either. It has been mentioned that the door latch could be bad and can keep it from spinning. Is that true for front loading machines as well as top loaders????
  • toyman75 Dec 19, 2007
    i am having same trouble. just wondering if switch fixed problem, becouse the light on control panel is green (lit) when door is locked on mine.
  • Welnetz Dec 26, 2007
    Will fill and drain but does not agitate unless I give the large drum wheel a push start. I have the back off to do this
  • 213 Answers
Yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Posted on Nov 20, 2007
My ATF6000ES Front Loading washer runs on any cycle for about 5 minutes then stops, and the display resets to the start and nothing more happens. Got an E48 code and ran "test 7" and the tub did not
Hello Nick Jensen, thanks for your post!
From what you have described your Frigidaire washer is displaying an error code of "E48" and you have changed the control board with the problem continuing to be present. An "E48" error code could be a possible problem with your door lock assembly, motor control board, or control panel. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. I hope this is helpful. -Matt
Jan 30, 2015 | Frigidaire Affinity ATF6000F Front Load...
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Agitator does not work
Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
likely the lid switch is bad - if not the ECU/timer is.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 43042 Front Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Wont spin or agitate
Not sure what you mean? if you have normal wash action then it is agitating in the wash cycle.  Otherwise if it doesn't agitate or spin but does fill with water then your motor or motor control board is bad.
Oct 27, 2007 | Frigidaire ATF6000ES Front Load Washer
Open the rear panel and look for a broken belt and does the motor spins. In case motor doesn't spin, check on its tags for 115/220V. Let me know with your results,for further assistance if will be needed. Good luck!
Aug 28, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore 44102 Front Load Washer Logo
515 people viewed this question
Sal De
 Brian Main
Brian Main
