Acer flat screen monitor, attached to laptop. Turns on and says 'no signal' occassionally works though for a short period. Works when connected to other laptops.
  • 4,234 Answers
If this monitor works when connected to other laptops, the problem is likely to be your laptop, not the monitor. I would suspect that there are bad comnections at the video connector of the laptop.
Dan
Posted on Jul 23, 2009
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
Have an 8 week old Acer Travelmate Notebook. Turn on after about 3 mins screen turns white. Am using windows 7. Have tried rebot ect nothing works. Thanks Kerri
MEAN NO SIGNAL AND THE MONITOR WHITE SCREEAN -IF THIS THE CONNECTER FROM VGA BOARD TO THE MONITOR ITS CUT REPLACE HIM OR MOVE BY U HAND
Mar 21, 2011 | Computers & Internet
I have an older acer laptop that has done me well the screen has faded almost to black . can you help me
connect it to a external monitor, send signal to monitor using the "F" keys
if that works then the lcd or the inverter on laptop needs replacing,
if it doesnt work then the laptop motherboard needs replacing or the laptop graphics card, which is quite expensive sometimes
Dec 31, 2010 | Acer Computers & Internet
How do I get my Sharp Aquos LC-32D43U to work as the monitor for my laptop computer. On key potential issue seems to be that the operating manual suggests pressing the "menu" button, followed by "setup"...
Not sure why u need to go to menu. If you want to connect lapotop to TV attach the cable turn on laptop and monitor and hit FN F5 the laptop screen will then be diusplayed on monitor Fn F9 turns it off
please4rate my help++++Thanks for using FIXYA
May 08, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
Acer AL1912 19" LCD Monitor goes black after power up
With the screen connected to the pc (which is running and putting out a signal) hold a bright light to the front of the lcd - a led flashlight works well. Do you see an image? If so then circuitry driving the inverter backlights may be at fault. I had this happen with a Dell Flat Screen, and found one of a pair of transistors which drives the backlight had developed a short.
Aug 01, 2009 | Acer AL1912 19" LCD Monitor
Screen not working on ACER 5315 laptop
First be sure you dont have an imput problem on your laptop while you are testing it. The input buton (swtich view) should be acessible via the Fn button and the F3-F8 on the keyboard (depends on your model) but it could looks like this : |[]| it really depends on the brands/models. It seems you experience some driver issues, but the driver should work for both devices... It's possible that your laptop screen or inverter are defective. But before saying so, be sure to try to switch views while you got the external monitor plugged in and see what happens. If only your external monitor works fine, you may have to replace some hardware in your laptop. I would personally contact the Acer technical support before spending any money on it though. Just in case... I hope it still in warranty cause it may be a bit expensive otherwise :(
Jun 08, 2009 | Acer Aspire 5315 Notebook
Both screens wont work
No mention of how much ram installed ???
Are you using ACER GRIDVISTA
This program handles the multi screen out put
or
Standard Screen Properties,,,,,,,
Try this
DESKTOP>Right click properties
DISPLAY PROPERTIES>Settings
With both screens connected.
There should be two windows displayed ,
a highlighted white one and a grey one
Click IDENTIFY.
ONE SCREEN-
Should display a number 1 on the screen it has attached.
TWO SCREEN
Should display a number 2 on the external screen.
Once you get IDENTIFY to work then set resolution sizes of both individual screen.Apply and ok to save settings
If using GRIDVISTA then set the setting for the output functions and save theme as a theme BOTH or LAPTOP AND EXTERNAL MONITOR and its accessible from the desktop right click.
Good luck I have a couple of these I use for my Media Centre wirelessly networked thru the house.Great machines.
Jan 11, 2009 | Acer Aspire 3680 Laptop
Monitor is connected to laptop jack and displays "no signal"
You have to activate the video out of the laptop.
Two ways to do this depending on how you want to use the monitor.
To use the monitor by itself laptops have shortcut keys.
Usually they involve using the Fn key and one of the F keys (Usually F3-F4-F5) KEy will either show two screens or say CRT-LCD
Pushing both keys at once will switch you to both screens, pushed again will just run the monito, Pushed again will return you to the laptop screen.
If you want to use the monitor as an extension of the monitor to be able to drag windos over to it then go to your display properties from the control panel and activate the monitor in the settings box. You'll have to click the monitor first then activate it as a extension and adjust the resolution here.
Fran
Oct 16, 2008 | Acer AL1916W 19" LCD Monitor
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
Computers & Internet Logo
David Payne
David Payne
