Question about Weather King 10AJA3601AH Air Conditioner
Bottom of it always fills up with water - Weather King 10AJA3601AH Air Conditioner
  • 520 Answers
They overlooked a few small details on these when they went into production. Clean any debris out and drill a few 1/4 inch holes around the perimeter of the lower casing. Be very careful not to hit the coils. If you evin nick them you will puncture them and loose the charge. Hope this helps. Good luck.
Posted on Jul 23, 2009
Runs without water
Water level is sensed by pressure against a diaphragm switch. This switch is always mounted above water level, and is connected to the bottom of the outer bowl by a plastic tube, usually 3mm ID. Either the tube has become blocked or the connection point. Also the diaphragm switch could be faulty.
Apr 01, 2014 | Roper Washing Machines
Tip
Krups espresso machine keep asking me fill up the water tank even it is already...
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons.
First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it cannot be fixed then you need a new float.
If you want to fix it temporary until you find a new float you can use a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
on Aug 16, 2010 | Coffee Makers & Espresso Machines
Doesn't always come on with hot water is turned on
Water heaters draw water into the bottom, and as the hot water heats, it rises and hot water exits from the top.
You might want to check each fixture, does the hot pipe (tubing)feel warm when you run it for a moment. Can you get warm water from some of the fixtures, but not others?
I'm bet there is a leak at the top of the intake which is filling from the top down, instead of bottom up.
Dec 27, 2012 | Water Heaters
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
Turned house water off to repair a leak. We have a surge pressure tank as we have well water. The dishwasher now does not fill up with water. We always get a surge of dirty water when we first turn the...
Yes.. the filter is right at the fill valve where the water connects to the dishwasher...
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Why does my water dispenser always has air in it? I always have to wait a few seconds of air sputtering out before I finally get water.
water is H2O,and it collects a small amount of air in its travels from the filtration plant to your house,(fill a glass from the tap,you will see bubles)so when the flow stops, it releases the excess air,(thats why you have to vent your central heating system every year)
read my profile
geoff.....
Jun 24, 2010 | Amana ARB2257CSR Bottom Freezer...
Won't drain
look for the float.
it will be in the bottom somewhere. This is how your dishwasher knows it has water in it.
your float might be cracked or full of water (then it needs to be replaced. if you just want to drain the dishwasher in the short term, you can always prop up the float (but this will prevent the dishwasher from filling up again, because it will think it is still full...)
Or sometimes it is an open bottom or air-trap type of float and it might just be filled up with grease and stuff.
Reach underneath with your finger (YUCK!) if you can, and scoop out the grease. Then it should work just fine.
Apr 13, 2009 | Dishwashers
Dream maker 400 cover always fill with water
You will need to either get a new cover or buy a new extralarge tarp and use as cover. Thanks jj505
Please rate
Apr 05, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Weather King 10AJA3601AH Air Conditioner Logo
52 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
